Please Andy, I do not want to open discussion 300B: SET vs PP.
Just atach.
Btw, you should try 4P1L push-pull.
No - I meant sound quality of each OPT!
Yes, I should try 4P1L PP. I have enough of them.....
Just atach.
There is at least one in "SE distortion" thread.
9-10 years ago, I moved from 300B-PP to 300B-SET only because of overpaid/inflated prices for 300B tubes.
Today, with cheap Chinese 300B, I'd choose for a push-pull.
If you decide to purchase James 6123HS (2k5, 3k5, 5k), I recommend using 3k5 tap because they are better treble. Due to lower Lp, the bass will be somewhat weaker than with 5k tap.
Lundahl no such problem.
Hi Yagoolar,
I have my own opinion about distortion, and I do not read opinions of other DIY-ers about it.
Hi Yagoolar,
We are not interested in your opinions of disinterest in our dis-interesting opinions of distortion.
You better read this next part with your eyes closed.
It's not opinion, it's physics. SE is slightly better at reproducing the smallest details, this is from a practical standpoint.
They same cancellation that makes PP measure lower in distortion inadvertently removes some of the texture of the music.
Not a big deal really.
If you are more concerned with having mostly unused watts then ultimate sound quality, then build PP
If you want the slightly better fidelity offered by SE, then you build SE.
This is a separate from the harmonic distortion differences of the two.
Joined 2009
Better fidelity?
More pleasing distortion perhaps but nothing to do with fidelity. You should do some measurements.
Best,
Better fidelity?
Best,
- Tubes / Valves
- Anyone familiar with James output transformers?
