hi andrew and black thanks for the quick reply . does any one have the pcb files for the higher voltage version on post #99 , #103
+ - 55v and + - 110 vcc
the my amps 1500w/4 ohms + - 70vcc and + - 140vcc
thanks for reply . what are the distortion tests ? and what are the heat levels when drivng 4 ohms?
Electrical wholesalers. They are called "busses" and are used in electrical switchboards for the mains electrical supply to houses. They come with standardised spacing so make sure you have the specs before you design anything using them.Where did you get the Copper Rails? Thanks
Abs
Failure?
How can you say that?
i am using this amp since 1 year........and no problem..........
this cheshtap amp is failure , dont try for (PA).
what voltage u used one year for pa?
wattaniya no problem in this amp
did u used for outdoor?
what dc v u used?
I use 55 + -,110 + - voltages
50+- 100+-
to get 1200w into 4 ohm 120v dc need.
I know but i have this source no problem i made 1 year ago no problem
what load u used?
- Cheshtap Power Amp
