Finished my DDDAC1794 with the new frontpanel.... those guys at Schaeffer do such a great job.
I am so happy 😀
Now I have to finish it with the 3 extra DAC boards....
Very nice! I am designing my panel with them too. Did you get just the front panel or complete chassis from them?
Chassis is from Modushop and I sent the frontpanel to Germany 😀
Thanks! Would you mind sharing the exact case as I like 😀
DDDummy Load
A real cool combination 😎
I just built some rugged stuff based on Modusop and Schaeffer as well 😛
totally off Topic, but may be of interest to all DIY with amplifiers and power supplies 😉
dddumy-load-versatile-power-dummy-load-tool
by the way, great THANKS goes to Reinhard for putting so much time and effort in a detailed Report of the test day with the new DAC set up 🙂
really GREAT 😎
Page 88 # 875
really GREAT 😎
Page 88 # 875
Case looks excellent. I reckon that it'll just fit a 4 stack in, but I'm considering adding another 4 to mine and going the "whole hog" with an 8 stack when I build the spdif/usb one. I've been looking for a chassis without luck so far. I may have to bodge one :-(
really GREAT 😎
Page 88 # 875
I've read through the mammoth report and it is indeed a work of literature. Did I really read that one of the testers prefers the mundorf blocking capacitors to the sowters?
The 4 deck DDDAC fits in this case? Finding a tall enough case can be an issue. A case that is 3U seems to be the minimum for the 4 deck.
Help
I received this dac kit a couple of days ago from Doede.
I have populated the boards.
The main board is one of his prototypes.The reason I bought this board is to have 75 Ohm connection(not interested USB)
The problem is only the power LED activates.
I have run my DMM over the boards and have voltage every where.
Both channels give the same readings.
I am a non technical retired person who loves kit building to pass some time.
I have successfully built,Class D & LM 3886 amplifiers.As long as the boards
are clearly marked (for dummies like me)
Is there any Australian members who I could send the boards to check out for me.
Sent with thanks,
elb(Les)
Sent with thanks,
elb(Les)
Hi Elb,
lets check a few things first . First of all, the LEDs are for USB only, not for SPDIF.
also, did you connect the spdif select pin to ground?
or send me some detailed Pictures (PM) of everything, so I can check for you.
what DC voltage do you read at the Output Pins (pos and neg) versus Common?
Hi Doede,
I cannot contact you via Email.
Our computer has issues,that is why I posted today on this forum.It is the only
way to communicate.
Connected the spdif to ground,no sound.
Out put measurements for L & R.
neg to pos = 0
common to pos= 2.74v
And just for the sake of it,common to neg=2.74v
Regards,Les
way to communicate.
neg to pos = 0
Regards,Les
Hello elp
have you remember to mount the 75ohm resistor ,parallel to the spdif input ?
best Bjarne
best Bjarne
Hmm...I figured out that it should be possible with 3 and 5mm stands instead of the standard 10mm and 15 mm stands.
So between the boards and the motherboard, and between the housing and motherboard.
I have an inner height of exactly 80mm.
Walter
Hmm...I figured out that it should be possible with 3 and 5mm stands instead of the standard 10mm and😀 15 mm stands.
Walter
You are correct. This is the way I did it also. The total height will be about 76mm. I also ordered the same enclosure for my DDDAC 😀
Roel
Hi Doede,
way to communicate.
neg to pos = 0
Regards,Les
These values are correct! ok, can you send some Pictures where I can recognize what you did?
- Digital Line Level
- A NOS 192/24 DAC with the PCM1794 (and WaveIO USB input)
