"NO advantage" to this alien "controversial feedback" ??? Hmmm...
Putting aside the bad PSRR , one could get high end performance with
a 4 device IPS/VAS. Can't do this with a VFA , the "stripped down"
3 device LTP/bootstrapped VAS LIN can only do .05% THD ... if that.
At 5 to 6 devices (LTP/CSS/beta enhancement), the LIN may JUST
match a Peeceebee.
Only at "full blown" level .... (LTP/cascode/CM/2 CCS/beta enhancement),
will a blameless match either the NX or (enhanced)VSSA designs.
So , a "CFA" can reduce device count in the IPS , but require "support"
(regulation).
By reading what has been said about "the sound", the REAL advantage
is the very high slew rate. 80v/us and above (like the Badger), will be
described as " detailed , excellent soundstage".
Then , I still have 2 simulations that require NO compensation 😀 .
Could a CFA be "idiot proof" ?
OS
match a Peeceebee.
(regulation).
OS
Zero, zip, nada, unless you are in the 500V/uS team.
- I would exchange anytime 500V/uS for a better PSRR.
- Complexity is a red herring.
- Anyway, if the .05% is correct, I thought that's all the audiophiles care for? And that the THD race is stupid?
So, a "CFA" can reduce device count in the IPS , but require "support"
(regulation).
So you are back to at least 6 devices.
Yeah, right, I've seen the same descriptions about the Wavac, 10% THD and a 200,000 squid price tag.
Nope, you are compensating an amp by using the devices parasitics. A big nono in my book, at least because it makes the whole thing more layout dependent. And BTW, you are happing for saving a couple of ceramic caps?
Anyway, you got a new toy, enjoy responsible 😀.
Joined 2009
Agree, but even in a VFA the device parasitics and pcb parasitics are part of the compensation so it's neither good nor bad.
Although Hugh has pointed out before that device parasitics are not always as 'pure' as an external cap.
Right. On a pure theoretical point of view, it is not so good than using a real (linear) capacitance.Nope, you are compensating an amp by using the devices parasitics..
Not sure who's Hugh and what he means by "pure" (why am I smelling something fishy here?), but device parasitics are always deeply nonlinear. Which makes the whole amplifier compensation bias dependent. E.g. you may have it stable at zero output, but oscillating as hell with outputs towards the rails.
Depending solely on the semi-con device parasitic capacitance for compensation is probably not a good idea as these parasitic parameters, Cob for example, are often highly non-linear and can cause distortions or instability in dynamic conditions. I would try to use reasonable sized external capacitors and not to let parasitic parameters dominate.
Assumptions here on primary and secondary affects of topologies which produce high SR numbers.
Complexity is very important to consider as well.... not as important as performance, however. But all else being approximately equal, less is best.
.05% is NOT good enough IMO.
PSRR - easily improved. I always reg the front end on any topology for I/O isolation. No 'extra' cost therefore for me.
In 40 Years (that is a lot of time) I never had problem with oscillations in audio CFA or remotely similar designs. Maybe just good fundementals in layout and wiring practices have been enough. But I also think the topology helps, too. Its apparently enharently quite stable... maybe even self correcting in a way. This is more easily learned by making VFA and CFA and building many of each and when you do it and then compare the experiences, you get the response that ostripper has. Happens over and over this way. We would like to understand this better.
And, yes I have the means, and the equipment and some knowledge to design and measure and test for such things. And, If you need to be really, really sure about stability, a small amount of over comp can be added without materially affecting performance.
-Thx-RNMarsh
Joined 2009
Hugh = AKSA
I remember he noted that Cob is non-linear, it is a capacitor with a poor dielectric to say the least. So having low Cob and then adding external capacitance makes for a better compensation scheme. But even with VFA, you still have that Cob as part of the equation. A similar thing can be said for adding emitter degeneration resistors, they are better controlled than the internal Re of the device.
Try using some of the modern power MOSFETs, these little buggers will oscillate by themselves.
Hugh = AKSA
I know they will.... so it isnt a VFA nor CFA issue.
Also, I use one's which don't do this quite so easliy and dont have problems.
-RM
By WALY - Nope, you are compensating an amp by using the devices parasitics. A big nono in my book, at least because it makes the whole thing more layout dependent. And BTW, you are happing for saving a couple of ceramic caps?
I'm a wise ol' man ... I would never do that. In fact ,
I will usually over- compensate to keep the magic smoke away. 😀
My point was the fact that a CFA CAN do this.
I alway's cover my butt .... If I don't like the "CFA" result , I have 3 proven
VFA designs to mate to that nice EF3 OPS I posted. I reverse engineered
(and built )the Luxman 120a (Hawksford VAS), but never heard it with it's preferred triple.
I'm on the Hawksford now (layout wise)...
OS
Hugh = AKSA
also, see #44 for CFA about device/circuit capacitance and distortion ....
-RM
Waly, presumably, there is some practical & useful info in these posts that will help us design better amplifiers, whether CFA or VFA.It is also interesting how, just a few years ago, CFAs were demonized for audio applications.
In all truth, the only thing you succeeded with this thread is perhaps a new fashion. I still haven't seen any non anectodic proof that what you call a "CFA" has any advantage over a standard and well designed Lin topology.
I don't think any sane engineer ever bought in the CFA hate and awe campaigns, anyway.
.. and subsequent posts all of which appear to be of the 'yus guys are all idiots & deaf' type ....
Meanwhile .. in an attempt to draw the discussion back to useful matters ..
This is your explanation in #3238 of the circuit you posted in #3149 in reply to Edmond's in #3135 claiming ' less THD, better PSR (I think) and less IPS dissipation'- Less distortions in the input stage mostly because of the local feedback loop (same as Edmond's).
- Better PSRR because the auxiliary transistors work at more or less constant Vce
- Less dissipation compared to the standard diamond buffer because the input stage transistors don't see the full supply voltage. Also, the auxiliary transistors only see the cascode supply voltage
- The input buffer bias current doesn't go through the gain stage, as a result the gain stage bias is defined only by the diamond buffer current source and two resistor ratio. A little simulation will show that this helps with the recovery when the amplifier is overdriven.
- Not my invention
- Not tried myself in practice, I'm as poor as the next beach bum.
- It's simulated, but not in LTSpice. Visually, if the gain stage and the auxiliary transistors are identical/matched, then they replicate each other, so from an AC perspective it doesn't matter to which emitter you connect the input diamond buffer.
Let's be clear about this. Have you simulated your circuit and also something similar to Edmond's (#3238) and found these advantages?
Yes, although they are all visible by inspection (except a quantitative analysis of PSRR and distortions).
I'm tired to be summoned.
-RM
Are you referring to the packing of the Mosfet or model/brand?
Not sure I understand your point about slew rate. Are you saying it's not an important (for audio) property of CFAs? My point is: anything over 1V/uS for each peak volt of output is a useless marketing driven number.
I said if the .05% is correct. Which IMO is not, it only shows an incompetent design. D. Self got 0.001% distortions with a classic VFA Lin topology (aka "blameless").
Quoting again Cherry:
To reduce distortions there are exactly three ways:
a) bias (e.g. class A)
b) distortion cancellation
c) negative feedback
It is funny to see how CFA people are throwing away the healthy concept of "first linearize then apply feedback" which is well illustrated in the LTP loaded with a current mirror, for the dubious (if at all, due to poor N/P device matching) distortion cancellation in the diamond buffer. Then in turn fighting for the last drop of loop gain to linearize the amp back to the best VFA values, only to realize that the CFA can't provide any extra loop gain compared to a VFA of the same ULGF. Which ends up with pushing the CFA ULGF up to non realistic values for a practical implementation.
But then I understand it's frustrating to accept that linear audio electronics is, for the last 20 years, into a dead end. Acoustics (speakers, rooms, propagation, etc...), I would put some money on that horse.
I think you have already stated there is zero advantage to CFA compared to VFA. Got it.
The only 'real' disadvantage I see of CFA is a pratical one - finding reasonably matched discrete N and P compliments. No problem with new IC processes. For DIY its much easier to find matched same type, esp N type.
I have made very low distortion amps without a large amount of fb or ULGF. Just need matched devices and the topology takes care of itself.
Thx-RNMarsh
This is absolute nonsense at every level - sub ppm distortion performance has been demonstrated in numerous designs on this thread.
Your tests were already proved technically wrong.
I agree that the diamond buffer can be an alternative to the LTP input stage, with pros and cons, as usual.
You failed to explain why a couple of years ago the same subjective crowd was boooing any attempt to introduce the CFA in audio, while today is marketed as the holy grail.
I don't recall the subjective crowd booing CFA. Most of the naysayers were on this thread . . .
Depends on what you mean by "matching". Even in modern IC processes, n/p Vbe matching is at least one order of magnitude worse than n/n or p/p.
AFAIK, you made preamps and headphone CFAs, the discussion here is about power amplifiers. By far not the same thing, for low power a CFA DSL driver like the TPA6120 will drive any headphone set with ppm distortions, ultra low noise and a huge bandwidth. Building with discretes anything to match the TPA6120 is very difficult, if possible at all (not to mention the cost factor).
Don't you love when people are running out of technical arguments? No worries, I'm not hoping to spoil your marketing campaign.
About sub ppm CFA amplifiers, you just made my point. Based on the results on this thread, try a blameless with 6MHz ULGF and 4 pairs of output devices running at 50W/8ohm output with +/-56V rails and see what you get, you'll be surprised.
Have fun
- CFA Topology Audio Amplifiers
