KEF LS50
Hey guys,
I appreciate the discussion here regarding the various uni-q drivers. After seeing Zaph's results on the q100 driver I decided to order a set for myself as well as the hts3001se to test the drivers.
I just wrapped up testing on the HTS3001SE coaxial driver and provided my own general thoughts throughout. It's pretty lengthy and there's a lot of pictures/data. I hope you guys get something out of it. I had a fun time doing it and look forward to some discussion on it. Particularly regarding the response of the woofer above 2khz.
If this isn't the best place to post forgive me. I just didn't think starting a new thread was necessary given the discussion here.
Here's the link:
http://medleysmusings.com/kefs-hts3001se-i-cracked-the-egg/
I tested the tweeter by itself, the woofer by itself, then tested the driver set with the supplied passive crossover. I didn't test the egg speaker itself as I didn't have real interest but I will try to do an FR of it sometime if there's a legitimate reason to.
A couple sample pictures...
Hi bikinpunk,
very interesting test results from the drive units in these speakers. I has not realised that KEF had made a HT version. It would be very interesting to read what you think about the sound quality.
Over the Christmas break, as planned, I managed to get a listen of the LS 50's at SuperFi in Camden, London. I was full of eager anticipation due to the reviews that I had been reading.
The LS50's were already on stands in the listening room but were not plugged in so I thought with a quick switch over of leads I would be hearing them for the first time! But to my utter amazement it took the staff nearly 20 minutes before they could get any sound out of them. They had a CD player, DAC, power amp set up, and did not seem to know what plugs went where!? They forgot to turn off the power amp whilst pulling out plugs so at one stage a "crack" came from the speakers that I swear must have blown the tweeters. When some Amy Whitehouse started playing I have never been more unimpressed by a set of speakers. I don't know what they had done, but I know that they could not have been right, if the tweeters were not blown then what? They sounded flat, dull, and grainy.
Wasted a couple of hours that morning I can tell you, and would not buy anything from SuperFi from what I experienced.
There is a test of LS50 in a Finnish hifi-magazine. The voicing is indeed bright and dry (monitor like?) Bass rolls off like a closed box until tuning fq and treble is high from 3kHz up on-axis. The overall verdict is very good for the price. Hifimaailma.fi - Etusivu
I guess you would like to have subwoofer(s) with them. I have a triplet of SEAS coaxials in closed boxes in my HT room and I like the sound very much. Could be rather similar to LS50.
They were demoed at TAVES last fall and, though admittedly under show conditions, I had the same disconnect between expectations and experience. Based only on TAVES a lowly pair of cheaper, and self-powered, Genelec 8030A would leave them for dead.
Hi guys, I have a long term love affair with KEF speakers and have used them at home and in car for many years.. All their uni-q versions. I even have a pair in my garage! Now, y question is this - I use pro audio drivers in my car (B&C DE250 & 18sound6ND430) and I fancy trying a set of uniq drivers again.. I did use the KEF Kar 160q for years and the 8" version of the same driver too..
My question Is this - which driver'should i experiment with?? I have been looking at the Q100 and the Q300 drivers, one is a 5.25 and the other a 6.5 cone. Are there big differences between the two units? And would one be better at mounting totally off axis in comparison to the other? The uniq I had in the car before were aimed nearly on axis in the kicks and were 6.5", so the Q300 drivers would slip straight into these builds, I just wondered if the 300 drivers lack compared to the 100 drivers? (I only ask as KEF seems to have used the 5.25 driver in many more high end applications, Blade, LS50 and I was wondering I the 6.5" cone is a disadvantage to pure fidelity?? The other option to mounting them in the kick panels in the car is to mount them flat in the doors.. This could give me the best stage width, but I would need the driver that works best at such an extreme off axis angle..
Also, what crossover point as I'd be running these active from a Rane crossover.
Having compared the Q100 and Q300 back-to-back, the Q100 drive unit is clearly superior, IMO. The Q300 struck me as sounding more like a typical "high end" speaker in the midrange, whereas the Q100 sounded more like music and less like the can it came in.
When I looked them up after the fact, I realized why: same tweeter size, same published crossover point, but the Q300 has a bigger midrange. So the Q300 does the "midrange mushroom cloud" thing that one hears in standard 7" midwoofer/flush tweeter "high end" speakers to some degree, because the woofer unavoidably narrows in coverage before the tweeter can come in, whereas the Q100 has better-controlled midrange off-axis response. The geometry of the LS50's driver is substantially similar, and the driver sets the overall directivity. So while I've not seen good polar measurements of the Q100 here's Stereophile's horizontal off-axis curve for the LS50:
(The lower-diffraction cabinet will make the LS50 smoother than the Q100. The other differences in drive unit and crossover may make the LS50 superior in other ways, but don't have as much an effect on the midband directivity.)
You see a little hole developing far off axis in the midwoofer-tweeter transition, but smooth performance closer in. Holes in the off-axis response have been shown to be relatively benign. Peaks (as one typically sees at the bottom of the tweeter's range in a so-called "high end" speaker, resulting in what I call a "midrange mushroom cloud")
So I suspect that the differences I observed between Q100 and Q300 go back to the drive units themselves, rather than to implementation.
The 8" Uni-Q in the Q900 is a different animal, with a much larger tweeter and lower crossover.
Thankyou Pallas, I appreciate your post a lot. So do you know the best xo point and slopes for the two drivers? (100 & 300)?? I have managed to borrow a set of Q300 to have a play with but am going to run them active..
Also, this peak you mention of the 300 driver, the swelling midrange, I'll hopefully be able to eq that out as I use Rane 30 band EQs together with an upgraded Rane active XO, what do you think?
I have REW and an audiocontrol rta to play with..
I wouldn't be so sanguine about the ability to EQ out the midrange mushroom cloud. It's not just an on-axis peak, but a basic difference in the amount of energy thrown out by the different drivers as one moves off-axis, because they have different radiation patterns. The only way to solve the midrange mushroom cloud issue is to cross the tweeter low enough that it matches the midrange's pattern in the crossover region. That requires taking polar measurements of each device.
But I suspect that the tweeter just won't go low enough to do it, because KEF's crossover uses the tweeter's rolloff as an element. (The Q100 has a very, very low parts-count crossover, just IIRC a single inductor on the midwoofer, and a cap + resistor on the tweeter. It's not perfect, but it's darned good.) I don't know what kind of crossover the Q300 has, because I've never owned one and never opened one up.
Still, you could probably get a very good result in your room with the Q300 driver by using your tools and perhaps some sidewall damping in the room. You'd have a higher likelihood of success if you ditch the RTA for a higher-resolution computer measurement system, such as FuzzMeasure (Mac) or Omnimic (Not-a-Mac).
I have the Kef LS50 and I was a bit dissapointed at first
boomy and a bit of reverberate in midrange.
I opened them up and replaced the filling from pieces of foam to roxul safe n sound fiberglass.
MUCH, MUCH BETTER.
Bass is more realistic and extend a bit more (subjective)
Bass port have about 8db less midrange radiation vs original foam at 1K (ok, only measured with my RS splmeter)
Pink noise sound a bit more neutral.
HF seem unchanged.
I wand to remove crossover and inspect caps.
they are wrapped in a kind of wax and one can't tell type or brand...
I'm waiting for silverplated solid wire to upgrade internal wiring before opening again.
Picture to follow.
MUCH, MUCH BETTER.
You might be interested in this Pimp (text in german, but the measurements and the like should be interesting):
http://www.hifi-forum.de/index.php?action=browseT&forum_id=104&thread=26095&back=&sort=&z=1
http://www.hifi-forum.de/index.php?action=browseT&forum_id=104&thread=26095&back=&sort=&z=2
Here are measurements of the stock LS:
http://www.hifi-forum.de/index.php?action=browseT&forum_id=30&thread=32137
Interesting thread here that has been dormant for a few years. I recently purchased a pair of these speakers from a local dealer, Halsten Entertainment, in Minnesota, and I have been listening to them in my townhome apartment living room area. My apartment has an open floor plan with the living room, dining room, kitchen and staircase combined into approximately 720 square feet (66.9 m^2).
I recently moved from a large house in another part of the US, so I reluctantly put my Klipsch Forte II floorstanding speakers in long term storage. My amplifiers are as follows:
  • gmarsh Wiener 2 TPA3118 PBTL dual mono Class D amplifier with Altec Peerless 15335A input transformers to feed unbalanced inputs into the amplifier's differential inputs. This amplifier is powered with an upgraded Astron RS-12A regulated linear DC power supply. Approx. 12 watts/channel
  • Dynakit Stereo 35 6BQ5/EL84 P-P tube amplifier recapped and modified with Dave Gillespie's Enhanced Fixed Bias (EFB) circuit. Approx. 17 watts/channel
  • McIntosh MC240 6L6GC P-P tube amplifier recapped with the bias supply and power supply upgraded with fast, soft recovery diodes. Approx. 40 watts/channel
My amplification also includes an Audio Research PH5 JFET/tube phono stage and Audio Research LS7 tube line stage, which provides 13dB gain unbalanced.
In moving to a smaller space, I needed smaller speakers, so I researched efficient monitors like the Reference 3A MM de Capo's and Omega Speakers Compact Hemp's thinking that I would need at least 90db+ sensitivity to work with my modest power amplifiers. I even considered putting my amplifiers aside in favor of powered studio monitors like the Dynaudio BM5A MkII monitors. I never considered the KEF LS50 speakers, because when I heard them at an audio show in California a few years ago, I was not impressed at all. They had a harsh, glaring upper midrange and no low frequency response at all.
Well fast-forward to last month while I was on vacation in Boston, I stopped in Audio Lab in Cambridge, Massachusetts and listened to a pair of LS50 speakers driven by a Cambridge Audio SS integrated amp. I was drawn into the sound much like Joe Roberts described in earlier posts in this thread. This was not the same speaker I heard at the audio show years before.
When I returned to Minnesota, I went to Halsten Entertainment to audition the LS50 speakers again. This time, the speakers were powered with a more powerful and more expensive Rotel SS integrated amplifier. Again, the speakers were very engaging, coherent and rich with tone. The large soundstage defies the size of these speakers. Well I decided then to purchase a pair at a good price offered by Eric at Halsten's.
I am very impressed that my Class D and Dynakit Stereo 35 amps can drive these speakers to very loud levels in my open apartment space. I am able to get strong room reinforcement for plentiful low frequency response where I do not need a subwoofer for thorough musical enjoyment. I like to use large scale orchestral music for listening tests, and these speakers do not disappoint at all. In fact, I can't go past 10 to 11 o'clock on the volume control without disturbing my neighbors.
I love the ability to really hear the mix that the recording engineers achieved with each piece Inlisten to. I can see why some professional sound engineers have even used these as studio monitors, they provide such a clear presentation in many respects. Poorly recorded and mastered music will not sound great with these speakers. The same can be said about sub-par quality upstream equipment paired with these speakers. I liken the sound quality to the highly acclaimed Tetra speakers in terms of their dynamic response, imaging and soundstage, and tonal accuracy.
I have yet to try my MC240 tube amp with these speakers, but I suspect I will be very pleased when I do. As others have stated elsewhere, these speakers do require some time to really break in, but once they do, they produce a "big" sound that belies their compact dimensions.
KEF's engineers have done an outstanding work developing such a well integrated speaker system. I don't think I would ever be tempted to open these speakers up and make any modifications. I am not sure one could take any Uni-Q driver and develop a satisfying system without all the sophisticated tools and experience that KEF employed to create their flagship speakers including the LS50. These are different from the often-referenced LS3/5a monitors, but similar in that they are game changers.
Just to share my LS50 tweeks. This speaker is outstandingly engineered in my opinion but inevitably built down to a price. I wanted to get the best possible performance out of mine without going crazy so...
The binding posts are fairly nasty, Mundorf TPCU670 drop straight in. I replaced all the crimp connections with soldered joints and used HDPE insulated solid core wire for the internal wiring.
The caps are good quality so they've stayed, and similar DCR inductors (didn't want to mess up the bass alignment)would be a marginal improvement for lots of money spent I felt. So I just replaced the sand cast resistors with Mills.
I Dynamatted the front baffle and cabinet sides but left the foam scheme in place. I may revist that in the future, but right now it's not a priority because I'm too busy enjoying my music....
Bass is much tidier and more tuneful, the noise floor has dropped a notch or too and the HF has now lost it's last trace of glare. I think it's insane how much these can give for the money in a small to medium size room. I've now lost all interest in DIY speakers 😱 😀
"Built down to a price?" 🙂
No, I don't think so. The LS50 is a speaker that's not competitively priced....considering the resources KEF has.
Check out the Q100 for a speaker that qualifies for your comment.
Dave.
I have heard the LS50 in two locations of the fairly mid-market Visions chain in Canada. They were completely underwhelming both times. If these are good speakers Visions doesn't have the equipment to drive them nor the sound rooms that flatter them. I would never buy them based on what I heard. Flat dull and sounded like a tin can.
