Haha Hairy caps. 🙂 It is wool and underneath it is Aluminium. Sometime I will add some oil. I have heard them on the output off a Buffalo dac. Was a little bit grainy in that place but maybe ok in this.
Make sure they don't short any pads under them.
Takman metalfilm is better than the pRP I use but also more exspensive. I think PRP is ok here ?
OK, bit softish, not too much. You got C2Y to offset tune in the end.
Yes thats true I am a little nerveus about that but I think I have placed them so they don;t.
When you will get the feel of the main body of tone after 48hrs of play or possibly more depending on the storage age of your whimsical lytics, it will be easy to tune either via C2Y or VTA on the TT, or via couplers. All things count for the aesthetic region of subtle preferences but the big picture is all builds will be between 10% of each other since the circuitry and layout are prefab. No worries.
Hehe 🙂 the 4 big 8000 uf 70 V caps in the supply box is about 40 years old but tested too be as new . They are from a big rest stock from Danish Wicon because some off my friends and also mister Steen Duelund himself bought the buildings.
I can't possibly guide the Danes, a wild bunch. You mix your soup and you let us know.🙂
I just hope you did not find the TT of Godzilla in the foundations and you plan to renovate it.😀
Wikings worked as soldiers for Greek 🙂 I have used about 80 off this caps and the sound is very good.
The Byzantine era guys you mean? Yes I know. The Varangian Guard.
Did you measure dissipation factor or ESR on those deep NOS 8mF? If you will see D>0.25 @ 100Hz they are sadly history.
A friend off mine who bought Wicon rest stock and wich I trust tell me they are as new. I paid about 4 dollars each. Have used them in a Class D amp. Class AB monoblocs and 6 channel amp. Maybe I shall bring them to Jensen and DCA wich I also know to measure them. amp etc. Only thing is to turn them slowly on the first time with a vario.
OK then. I wonder what happened with Marra now. He did not say yet if he managed to fix his other channel he had the accident with...
2SK369BL Transistors - 26 in stock to buy, photo, pdf datasheet, rfq, obsolete
Only 16 . I just bought 10 for Teddy Pardo reg. They are easily blown.
I'm waiting on delivery of some BC550's.They should have arrived yesterday but didn't so hopefully today
Regarding the 117's I have a reading of 75 ohms across the outer pins so they are ok yes?
Any concern regarding being fakes or is it a confirmed source?
Hi Salas, would 10R be alright as source resistors for k369bl measured at 10.04mA? Or should i stick to 9.1R ?. Thanks .
Quan
Quan
So where are people sourcing the 2sk369? Ampslab is out of stock ATM.
Tea Bag was matching for the mini-kits else it was ampslab or ebay I think.
They measure OK.
Quan
Its 3.0R or 3.3R. If you use 3.9R it will lose half a dB of gain but it will be tad steadier. Use up to 0.5mV output cart when employing two K369BL.
P.S. 9.1R-10R is for 14mA Idss.
- Analogue Source
- Simplistic NJFET RIAA
