P.Audio drivers components
Not Enough
Hi Guys!
I'm dispose of two basses and two tweeters P.Audio (bass:http://www.paudiothailand.com/pdf/products/E15-200S3.pdf and tweeters: http://www.paudiothailand.com/pdf/products/PHT-404P.pdf)
What can with the drivers to do, or what type of boxes you recommend them?
Which crossover etc. ...🙄
Please help as this area since I'm an amateur?🙁
The tweeter does not go low enough to get a good acoustic marriage with the 15” woofer.
Add a mid-range driver [1] to cover 300-3000 Hz Speech Range.
Isolate it from the woofer with a sealed back-box.
[1] P.Audio System Co., LTD
Use a sealed enclosure for the woofer and mount the tweeter in a cutout above the mid-range driver.
Too determine dimensions use a loudspeaker box design software & ‘plug & chug’ driver parameters.
Designing and testing the crossover will by the most daunting challenge.
WHG
:sax::eguitar:😱😉
You could improve your system if you follow PAudio recommending 8" or 10" woofer to match that tweeter. If you like 15" woofer, you should get a better tweeter to match the woofer.
Thank seanny at the suggestion:up:
But such a combination is very nice and gives a powerful sound!
Of course, with the Audio amplifier M-100 (Don Petru)!
And with the tube pre-amp (tube preamp-SIMPHONY)😱:violin::sax::eguitar:😉
A killer sound!:xmastree:
Happy new year!!:hohoho:
cheers!:cheers:
