Based on sonics... which do you prefer ?
Based on sonics which do you prefer.
  • Ruby
    Votes: 14 42.4%
  • Opal
    Votes: 19 57.6%
  • Total voters
    33
  • Poll closed .
I will soon be able to design a 'high-end' preamp and impress journalists!!
Easy, just throw some random BS in a nice machined aluminium case and sell it for the price of a small car. 😀
Make sure the noise on the l&r channels is not correlated.
Random noise is normally uncorrelated. How would it get correlated?
FWIW, re the earlier comments about "information": paradoxically, random noise contains more "information" than a sine wave. The sine wave is "deterministic", if you know its amplitude, frequency and phase now you can predict them at any point in the future, so it contains no information whatsoever.
The above discussion is a practical example of this: low-frequency noise carries information about the size of the acoustic space in which it exists.
Noise patterns from Mooly's A ... Z files test, 'silence' before the music starts.
By having a common source e.g. a common PSU. So 'high-end' preamps should have separate PSUs for each channel to help to de-correlate the noise. Separate mains supplies and quite different EMC characteristics would be even better. If one channel gets local AM interference and the other gets hash from Wi-Fi and mobile phones then this will be largely uncorrelated.
Yes. I guess this falls into the category of 'not a lot of people know this'. Actually, it might be better to say that an information-rich channel sounds just like random noise.
I don't know if it is, if you use a stereo device.
Simple test to check this is record the noise of a device, normalize and playback at normal levels. If it sounds like a point source its correlated, if you can't locate it its decorrelated.
Sound added.
To my knowledge:
A sine does have information: Amplitude, phase and frequency.
Noise has no information.
Or can we put information in the spectrum and amplitude of the noise?
An experiment anyone can try at home is to use FLAC to compress, say, 1 minute of white noise, and 1 minute of a 1kHz sine wave. Which gives the larger file? What is the implication in terms of information content?
White noise is the sum of all possible signals, the most information-rich signal possible in the bandwidth available. The only fundamental difference between signal and noise is that a "signal" somehow encodes a message of interest to humans. The more efficient the channel coding, the harder it is to tell the output from white noise unless you happen to know the key.
http://en.wikipedia.org/wiki/Kolmogorov_complexity
By a similar argument you can show that Skrillex is a higher form of music than Elgar. 😉
Kolmogorov complexity - Wikipedia, the free encyclopedia
Thanks, I think I get it.
Question for all you digital gurus 🙂
Quick question while we have such a knowledgeable group of folk in this thread.
I have a Philips test CD containing 99 test tracks. The disc is playable on any standard player.
No PC I have tried it in will play it. Audacity will not import data from it. Why ?
Audacity gives a message saying the data has to be ripped to wav first. But I can't ! Media player says the tracks are "audio data only" and not playable. What is different about this test disc ? It is as "Red book standard" as its possible to get.
