Photo Gallery
my daily amp
Hi Professor, I'm curious, what are these two elements, up to the right on fourth picture, (P3C8 ? , pale green, lots of pins) something to do with the nixie dsplay - input selector?
Cheers
J.
Hi! This is relay RES8 (РЭС8) to switch the secondary windings of output transformers.
Hi Professor,
please tell me what kind of transformers you use and where do you got it.
I´m plannig to build a stabilized powersupply with russian parts only. I have a 6s33s, a 6sh1p and a bunch of caps and resistors all from russia.
Thanks a lot,
Hilmar
For the power supply I rewound industrial 160 w transformer OSM-0,16 (ОСМ-0,16) Output transformers made ​​a firm from St. Petersburg http://goldenmiddle.com/english/indexen.htm
P.S. Be careful with old capacitors, especially electrolytic.
Best regards, Oleg
Attached is my latest amplifier - Pentode output with adjustable fixed bias. Screen is regulated via VR tubes. 5687 driver. James Output transformers and Edcor power iron.
With the fixed bias, multiple output tubes can be used - KT88, 6550, EL34, KT66, 6L6GC, etc. Also included an optional plate cap in case I ever get a pair of TT21s or 12E1s.
EL34/6CA7 ultra linear single ended amp
This is a study build, I hope to move it all into a more finished case with wood and brass eventually....
This amp was designed by Professor Iwamura of Kanagawa University and featured in a design contest in MJ magazine 2012 Jan. edition.
my build blog is here if you want more detail.....
EL34 ultra linear single ended amp. Designed by Iwamura Yasuo | twiddlingmyknobs
