Best TH for Dayton PA380 15"?
I've been following a lot of threads on this board for a few months, and I really have myself set on building a tapped horn with the Dayton PA380-8 drivers. There is so much useful information on this website, and I'm having a hard time wrapping my head around it. I'm doing my best to learn hornresp, but I use linux, and it crashes on me a lot while I try to run it under wine.
Anyways, perhaps some of you who are more skilled than I can direct me towards which of the tapped horns would work best with the dayton drivers? I'm not a terribly skilled woodworker, but I'm sure I could put together the SS15 or the JBell mini TH cubes, or even the stadium horns if that is recommended. I have a cargo van to move everything with.
My use of the subs would be for live sound, mainly in a 150-200 person capacity room. There is the occasional 300+ gig, but thats maybe one a year. I am looking to add the subs for kick drum and some low end for the bass, so I don't think I need it to go terribly low. I'm more concerned about efficiency and SPL.
I already have a Yorkville AP2020 amp which would give me 700 watts per side at 4ohm. I plan on purchasing a DCX2496 or a used DBX driverack to set the system up with. I would be using everything under a set of community tops I already own, but am hoping to eventually build JBell's HS12 tops as well.
I'm hoping to make some sawdust over the weekend. Thanks for any advice.
GM, I was planning on building four cabs, two per side. I thought this would be better than one cab per side with different drivers. Maybe I'm wrong on that. Are their better drivers in the $140-150 a piece price range that I'd be better building two cabs instead of four cabs with the dayton drivers?
turbodawg, If I go with ported boxes, would four single 15" cabs work as well as two 2x15s? I would imagine it would. It would be a lot easier for me to move that way.
.. I'm more concerned about efficiency and SPL...
Not an answer for your question.. But if targeting SQ and a reasonable lower end BW concerning the short xmax + long healthy Driver life expectance instead over 😱 SPL and 😡 efficiency..
b🙂
