Valve Itch phono
Being away on autumn holiday I had no other tools then paper and pen so I made a physical layout on how a combined Itch+6V6 pre could look like. One channel only, the other gets mirrored. Some rcrc to go also.
Looks like a valid plan. Since all the builds here were about the Itch stages alone and mainly built with in-line ground bus, you will be making a novel package. OTOH no stock experience on grounding or other details you may encounter, but you are veteran on such, no worries.
