and new again
Interesting design - some sort of hybrid between a vented and compound horn?
Would be interesting to see some raw frequency response and impedance measurements.
friends the video about tham12 a friend got job from food shop where the location is near the phuket beach. the video took in the morning. in the night ill post again. very fun because hv lot of Foreigners who dancing on there.
Tham12 got job near phuket beach
the video c cab played. some friends go there n told me it work great.
18 THA C Cab tested
18 THA C Cab tested
the built pics
This looks like quite an interesting design. I'd love to see an impedance response curve for it. Did you add any bracing to the top part of the enclosure? Have you tried using it with the box turned so that the vent is to one side instead of at the bottom? Does it sound any different?
friends this boxes try to build 15 tha stl
This looks a bit different to the 18 THA. The bottom part is sealed. Is this a sealed rather than vented design?
the v1 measure the blue use nanova driver . the factory is near my location. the red is lion driver i dont sure from there.
Is this the raw response of the speaker, or are you applying any filtering to the signal being fed to the speaker?
hi steele these cab bought a week ago. if possible in the first december that will hv paudio meet diy II in part of my big group in trang provice i will tell p audio measure this cabs again. and now i still dont use like u say.
no hv any filter guy.
steele it is sealed tl cab
- Subwoofers
- TL sub project
