Ian asynchronous I2S and S/PDIF FIFO KIT group buy
GBVFIFO01 : jbercovici : 1x I2S FIFO KIT V3.80, 1x Package of Universal SMT XO Adapters lot of 5, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket,
GBVFIFO02 : Celihman : 1 pcs I2S FIFO KIT, 1 pcs Dual XO Clock board
GBVFIFO03 : APK 1x FIFO KIT, 1x Si570 Clock board, 3x TPS7A4700 Regulator, 1x FIFO isolator, 3x Battery management 1 x s/pdif 1 x I2S backdoor plus
GBVFIFO04 : duster1 : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 1x S/PDIF Interface Board, 1x Finished FIFO Isolator, 1x Si570 Clock board with Si570, 2x Finished TPS7A4700 Regulator, 1x Battery management, 1x I2S backdoor, 1x SMT XO Adapters Kit
GBVFIFO05 : chi0001: bIII adapters pcb x4, tps7a4700 x4
GBVFIFO06 : hsi68 : 1x I2S FIFO KIT V3.80, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 1x Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket, 4x 6” double-ended 50 ohm coaxial cable
GBVFIFO07 : malarkey : 1x I2S FIFO KIT, 1x Dual XO Clock Board, 2x S/PDIF Interface Board, 1x Finished FIFO Isolator
GBVFIFO08 : mcluxun: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board
GBVFIFO09 : casshan : 1 x I2S FIFO KIT v3.8,2 x Finished FIFO isolator board v2.5,2 x Si570 Clock Board V3.5 (with Si570),2 x Finished TPS7A4700 low noise regulator board V2.5
GBVFIFO10 : hangguy: 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 2x battery management board, 1x Finished TPS7A4700 low noise regulator board V2.5
GBVFIFO11 : luisbock
GBVFIFO12 : kazap: 1x i2s FIFO kitv3.80, 1x Dual XO Clock Board, 1x finished isolator, 1x TPS7A4700, 1x Battery management, 1 x S/PDIF , 1 x I2S backdoor KIT, 4x 6” 50 coaxial cable, 1x XO Adapters, 10x SMT U.FL socket
GBVFIFO13 : iskwon: 2xI2S FIFO KIT and 2x Dual XO Clock board
GBVFIFO14 : audiopassion
GBVFIFO15 : ctrange: 1xI2S FIFO KIT V3.80, 1xDual XO Clock board V3.3, 4xSMT U.FL socket, 1x12” double-ended 50 ohm coaxial cable, 1x6” double-ended 50 ohm coaxial cable, 1xPackage of Universal SMT XO Adapters.
GBVFIFO16 : LOBOONE: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface Board, 1 x Package of Universal SMT XO Adapters lot of 5, 1 x Additional BIII adapters PCB , 1 x SMT connector package for BIII adapters, 1 x 10P 1.0mm FFC/FPC cables combo, 1 x Finished FIFO isolator board V2.5, 1x Finished TPS7A4700 low noise regulator board V2.5, 1 x Passive Battery Management Board V2.5 Mini KIT
GBVFIFO17 : errmoo I2S FIFO KIT V3.80, Si570 Clock Board V3.5(with Si570), S/PDIF Interface Board
GBVFIFO18 : sernikus I2S FIFO + Dual XO
GBVFIFO19 : TonyB: 1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x S/PDIF Interface, Board, 1 x Package of Universal SMT XO Adapters, 1 x PCM1704 board, 1x I2S backdoor
GBVFIFO20 : korben69 : 4 x Bare PCB of TPS7A4700
GBVFIFO21 : Billyk: 14x SMT U.FL socket, 2x 6” double-ended 50 ohm coaxial cable, 4x 4” double-ended 50 ohm coaxial cable
GBVFIFO22 : pavelal: I2S FIFO KIT V3.80, Dual XO Clock board V3.3,S/PDIF Interface Board, 10 x SMT U.FL socket, 8 x 6” double-ended 50 ohm coaxial cable, 3 x 12” double-ended 50 ohm coaxial cable, Package of Universal SMT XO Adapters lot of 5, Finished FIFO isolator board V2.5, 2 x Finished TPS7A4700 low noise regulator board V2.5, Passive Battery Management Board V2.5 Mini KIT
GBVFIFO23 : JustBuildLspkAS: 2 sets with optimize SQ/ minimize board qty for TDA1541 and PCM1704/63
GBVFIFO24 : crobbins5421: 1 x Finished FIFO board, 1 x Dual XO Clock Board, Universal SMT XO Adapters lot of 5
GBVFIFO25 : Iancortez: 4 x SMT UFL socket, 2 x Additional BII adapter pcb, 2 x SMT connector package for BII adapters
GBVFIFO26 : LuisMCP: 4 x BIII Adapter PCB.
GBVFIFO27 : TNT: 1 FIFO board (no clock). 3x Finished TPS7A4700
GBVFIFO28 : clsidxxl :1x I2S FIFO KIT V3.80,1xDual XO Clock board V3.3,1x Package of Universal SMT XO Adapters,1x Finished FIFO isolator board V2.5,1x Finished TPS7A4700 low noise regulator board V2.5,3 x 6" coax cable and 3 x SMT U.FL socket
GBVFIFO29 : Ryelands: 1 of I2S/FIFO kit; 1 of finished isolator board; 1 of Dual-XO Clock board; 2 of finished TPS7A4700 board; asstd cables.
GBVFIFO30 : jcga: 2 x TPS7A4700 finished boards; 3 x TPS7A4700 PCB only; 2 x passive Bat management minikit; 2 x U.FL socket kit; 1 x xoadaptator kit
GBVFIFO31 : canvas: 1 x I2S FIFO KIT V3.80, 1 x Dual XO Clock board V3.3, 1 x S/PDIF Interface Board
GBVFIFO32 : sidiropa:1 x I2S FIFO KIT, 1 x Dual XO Clock board, 1 x Additional BIII adapters PCB , 1 x SMT connector package for BIII adapters, 1 x 10P 1.0mm FFC/FPC cables combo, 1 x Finished FIFO isolator board V2.5, 1 x Passive Battery Management Board V2.5 Mini KIT
GBVFIFO33 : hochopeper: 2 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 2 x finished FIFO isolator, 1 x Si570
GBVFIFO34 : zapio : 1 x Si570 , 2 x finished FIFO isolator
GBVFIFO35 : fregones : 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator, 1 x Si570
GBVFIFO36 : fukinspud : 1x finished I2S FIFO board, 1x finished Dual XO Clock Board, 1x finished S/PDIF Interface Board, 1x Finished FIFO Isolator, 1x finished Si570 Clock board with Si570, 2x Finished TPS7A4700 Regulator, 1xfinished Battery management, 1x finished I2S backdoor, 1x finished SMT XO Adapters Kit
GBVFIFO37 : nedi: 1x FIFO Kit v3.80, 1x Dual XO clock board v3.3, 1X Finished FIFO Isolator board v2.5, 1x S/PDIF interface board, 1x I2S backdoor kit for S/PDIF board, 1x Passive Battery management board v2.5 mini kit
GBVFIFO38 : manolo2001: 2x finished I2S FIFO board, 2x finished Dual XO Clock Board, 1x finished S/PDIF Interface Board, 2x Finished FIFO Isolator, 1x finished Si570 Clock board with Si570,1x Package of Universal SMT XO Adapters lot of 5, 2xFinished TPS7A4700 low noise regulator board V2.5, 10 x SMT U.FL socket, 10 x 4” double-ended 50 ohm coaxial cable, 6 x 6” double-ended 50 ohm coaxial cable
GBVFIFO39 : Peterma: 1x finished I2S FIFO board, 1x finished Dual XO Clock Board,1x Finished FIFO Isolator
GBVFIFO40 : Tony_T: 1x I2S FIFO KIT V3.80, 1x 10P 1.0mm FFC/FPC cables combo, 1x Si570 Clock Board V3.5(with Si570), 1x Finished FIFO isolator board V2.5, 3x Finished TPS7A4700 low noise regulator board V2.5
GBVFIFO41 : Heffa: 1 x Package of Universal SMT XO Adapters lot of 5, 2 x Additional BIII adapters PCB, 2 x SMT connector package for BIII adapters, 4 x 4” double-ended 50 ohm coaxial cable
GBVFIFO42 : curryking 1 x Dual XOClock Board,2 X Package of Universal SMT XO Adapters Kit,1 x Si570 Clock Board V3.5(wuth Si570),1 x Finished TPS7A4700 low noise regulator board V2.5,1 x SMT finished Battery Management V2.5 Mini Kit, 2 x 6" double-ended coaxial cable
GBVFIFO43 : vanwykca: 3 x additional BIII adaptor PCB, 3 x SMT connector package for BIII adaptors, 5 x finished TPS7A4700 low noise regulator board V2.5
GBVFIFO44 : Joonas: 1x fifo kit, 1x dual clock board, 1x spdif board, 1x finished isolator boards, 2x adapters for crystek if you still have them, 1x nos pcm add-on from the other thread
GBVFIFO45 : wl336: 1x fifo kit, 1x dual clock board, 2x adapters for crystek if you still have them
GBVFIFO46 : _oxygene: 1x FIFO Kit v3.80, 1x Si570 Clock Board V3.5(with Si570), 2x Finished FIFO isolator board V2.5, 3x Finished TPS7A4700 low noise regulator board V2.5, 10x SMT U.FL socket, 6x 4” double-ended 50 ohm coaxial cable, 4x 6” double-ended 50 ohm coaxial cable, 1x Package of Universal SMT XO Adapters lot of 5, 1x Additional BIII adapters PCB, 1x SMT connector package for BIII adapters, 1x 10P 1.0mm FFC/FPC cables combo
GBVFIFO47 : frd__: 10x Bare PCB of TPS7A4700 low noise regulator
GBVFIFO48 : palmito: 1 FIFO board
GBVFIFO49 : brettlb: 2 x FIFO board, 2 x Isolator board, 1 x Si570 with Si570, 4 x finished regulator boards.
GBVFIFO50 : davej: 1 x FIFO kit, 1 x dual XO, 1 x finished isolator board, 1 x finished TPS7A4700 regulator
GBVFIFO51 : flowerpot: 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator
GBVFIFO52 : Bennyboyvg: 1 x FIFO board, 1 x Si570 board (with Si570), 1 x finished isolater board, 1 x finished regulator board, 1 x additional BIII adapters PCB's, 1 x SMT connector package, 6 x 4" coax cable, 7 x SMT U.FL socket
GBVFIFO53 : Popolvar: 1 x FIFO board, 1 x dual XO
GBVFIFO54 : necplusultra: 1 fifo board,1 x Si570 board (with Si570), isolator board, 5 TPS7A4700 boards
GBVFIFO55 : crowlie: 1x I2S FIFO KIT V3.80, 1x Dual XO Clock board V3.3, 1x Finished FIFO isolator board V2.5, 3x Finished TPS7A4700 low noise regulator board V2.5, 4x Passive Battery Management Board V2.5 Mini KIT, 10x SMT U.FL socket, 8x 4" double-ended 50 ohm coaxial cable, 6x 6" double-ended 50 ohm coaxial cable, 1x Package of Universal SMT XO Adapters lot of 5, 1x 10P 1.0mm FFC/FPC cables combo
GBVFIFO48 : palmito: 1 FIFO board, 10 PCB of TPS7A4700 low noise regulator
GBVFIFO56:4 x Dual XO Clock Board,4 x 6" double-ended U.FL cable,2 X Package of universal SMT XO Adapters Kit
GBVFIFO46 : _oxygen: 1x FIFO Kit, 1x Si570 Clock Board (with Si570), 2x Finished FIFO isolator board, 1x SPDIF Interface Board, 1x i2s Backdoor Kit, 3x Finished TPS7A4700 low noise regulator board, 1x SMT finished Battery Management Mini Kit, 10x SMT U.FL socket, 6x 4” double-ended 50 ohm coaxial cable, 4x 6” double-ended 50 ohm coaxial cable, 1x Package of Universal SMT XO Adapters lot of 5, 1x Additional BIII adapters PCB, 1x SMT connector package for BIII adapters, 1x 10P 1.0mm FFC/FPC cables combo
GBVFIFO56:curryking: 4 x Dual XO Clock Board,4 x 6" double-ended U.FL cable,2 X Package of universal SMT XO Adapters Kit
GBV I2S to PCM board waiting list
Order number: ID and quantity
GBVPCM01 : TV Man x 2
GBVPCM02 : merlin el mago
GBVPCM03 : rtd
GBVPCM04 : jameshillj
GBVPCM05 : erin x1 (or 2)
GBVPCM06 : Nikola Krivorov x1
GBVPCM07 : Rupor54
GBVPCM08 : vitalica
GBVPCM09 : analog_sa x 1
GBVPCM10 : andrea_mori x 5
GBVPCM11 : dsavitsk
GBVPCM12 : tagheuer
GBVPCM13 : hirez69 x 2
GBVPCM14 : ccliu x 2
GBVPCM15 : BDL
GBVPCM16 : cddumat
GBVPCM17 : regal x 2
GBVPCM18 : zoran
GBVPCM19 : Jogi
GBVPCM20 : Zen(zenelectro) x 2
GBVPCM21 : Buzzforb
GBVPCM22 : SPWON
GBVPCM23 : crobbins5421 X 2
GBVPCM24 : marcus1 x1 (or 2)
GBVPCM25 : casshan x 2
GBVPCM26 : Dweeb99 X 2
GBVPCM27 : jackw X 2
GBVPCM28 : kazap X 2
GBVPCM29 : danzup x 3
GBVPCM30 : Giordano x2
GBVPCM31 : Tony_T
GBVPCM32 : Tubo x1
GBVPCM33 : clivem x2
GBVPCM34 : noizas x4
GBVPCM35 : JoeyDD x2
GBVPCM36 : skullaudio
GBVPCM37 : dinos8746 x2
GBVPCM38 : dvb-projekt
GBVPCM39 : bisesik x2
GBVPCM40 : guglielmope x1
GBVPCM41 : Valeriano x1
GBVPCM42 : mhgawel x1
GBVPCM43 : av-trouvaille x 1 (or 2)
GBVPCM44 : iloveswan x1
GBVPCM45 : dtses
GBVPCM46 : Flyboi X1
GBVPCM47 : Lil' Knight x1 (or 2)
GBVPCM48 : skippyboy x1
GBVPCM49 : acccruz x1 (or 2)
GBVPCM50 : WhiteBull x1
GBVPCM51 : hksidney x 1
GBVPCM52 : vts2006 x 3
GBVPCM53 : JustBuildLspkAS.x3 &1 fifo kit finished for pcm1704 (ihave AD1862 ,pcm63,pcm1704)
GBVPCM54 : 54: PET-240 2 * TDA1541
GBVPCM55 : TonyB
GBVPCM56 : damohpi x1
GBVPCM57 : iloveswan x 1
GBVPCM58 : Joseph K x 2
GBVPCM59 : mefistofelez x2 (pcm63P)
GBVPCM60 : JLOP x1 (WaveIO, AD1865 NOS SRPP)
GBVPCM61 : sceglar x1
GBVPCM62 : 4me2ctv x 1
GBVPCM63 : tubesguy x 1
GBVPCM64 : ctrange x 1
GBVPCM65 : spm x 1
GBVPCM66 : Joonas x1
GBVPCM67 : Loboone x 1
GBVPCM68 : flowerpot x 1
GBVPCM69 : pavelal x 1
GBVPCM70 : Steve Ha x 1
GBVPCM71 : new2hifi x 1
GBVPCM72 : Superdad x 1 (WaveIO, PCM1704K, discrete I/V)
GBVPCM73 : Greg Stewart x 1
GBVPCM74 : panther5429 x 1
GBVPCM75 : supra x 3
GBVPCM76 : Clsidxxl x 1
GBVPCM77 : Uchi Deshi x 1
GBVPCM78 : kvl x 1
GBVPCM79 : palmito x 1
GBVPCM80 : davej x 1
GBVPCM81 : crowlie x 1
GBVPCM82 : WhiteBull x2 (and one Dual XO Board, in case ones left)
GBVPCM83 : nedi x 1
GBVPCM84 : gonmar x 1
GBVPCM85 : LuisMCP x 1
GBVPCM86 : chansiukwing x 2
GBVPCM87 : tassosk x 1
GBVPCM88 : NATDBERG x 2 (NOS dual differential 2x D20400 project, NOS 384KHz TDA1541A project later)
GBVPCM89 : Jcastellano x1
GBVPCM90 : Marek x1
GBVPCM91 : SVStube x 3*
GBVPCM92 : mksung x 1*
GBVPCM93 : JimS x 2
GBVPCM94 : brettlb x 2
GBVPCM95 : DUC985
GBVFIFO57 : Alcaudon: 1 x Dual XO Clock Board, 5 x BIII Adapters PCB, 3 x SMT connector package for BIII adapters, 10 x SMT U.FL socket, 3 x 4” double-ended 50 ohm coaxial cable, 3 x 6” double-ended 50 ohm coaxial cable, 3 x 12” double-ended 50 ohm coaxial cable.
GBVPCM03 : rtd
GBVPCM07 : Rupor54
GBVPCM08 : vitalica
GBVPCM11 : dsavitsk
GBVPCM12 : tagheuer
GBVPCM15 : BDL
GBVPCM16 : cddumat
GBVPCM18 : zoran
GBVPCM19 : Jogi
GBVPCM21 : Buzzforb
GBVPCM22 : SPWON
GBVPCM31 : Tony_T
GBVPCM32 : Tubo x1
GBVPCM45 : dtses
GBVPCM55 : TonyB
GBVPCM65 : spm x 1
GBVPCM78 : kvl x 1
GBVPCM83 : nedi x 1
GBVPCM90 : Marek x1
GBVPCM93 : JimS x 2
GBVPCM95 : DUC985
GBVPCM96 : ruupie x 2
GBVFIFO58 : ruupie: 1 x FIFO board, 1 x Si570 board (with Si570), 1 x finished isolater board, 1 x finished regulator board, 2 x BIII Adapters PCB, 2 x SMT connector package for BIII adapters, 10 x SMT U.FL socket, 3 x 4” double-ended 50 ohm coaxial cable, 3 x 6” double-ended 50 ohm coaxial cable
GBVFIFO59 : tofurky : 1x finished TPS7A4700 regulator, 2x TPS7A4700 bare pcb
GBVFIFO60 : MarcellD : 1 x i2s FIFO kit, 1 x dual xo board, 1 x spdif interface, 1 x finished FIFO isolator
GBV: Ian I2S to PCM board and FIFO KIT (partly) group buy is running
TO those who are on the I2S to PCM converter board interesting list
Finally I get everything ready. I’m sorry for keeping you waiting for long time. I thank you for your patient.
1. I2S to PCM board is a unique design to bridge NOS Multi-bit DACs with I2S sources by new low jitter technology. Though it was confirmed working with many DACs by real testing, but I still couldn’t guarantee it works with all kind of NOD DACs. Please read the user’s manual with careful to make sure it works for yours.
2. All I2S to PCM boards will be carefully tested and confirmed functional before delivery. But your DAC system could be very specific, by supporting the I2S to PCM board, I may not be able to solve problems of your whole DAC system. If you have issues with I2S to PCM included in your system, please post your problem on the R&D thread, many other diyAudio members and I would be glad to help: http://www.diyaudio.com/forums/digi...1541-fifo-universal-i2s-pcm-driver-board.html
3. Your order number will be GBVPCM + interesting list number, for example GBVPCM12.
4. You can order I2S to PCM converter board, as well as other available items on the GBV order form, but please do not order FIFO and dual XO clock board which I don’t have enough stock for this time.
5. U.FL sockets and cables are not standard equipped except for MCLK; please order them extra if you need more.
To those who are on the FIFO KIT waiting list
Names on the FIFO KIT waiting list are still not enough to launch a new production. So, I decide partly supply this list with the stocks I’m keeping right now. At least, some of you can get the KIT without waiting too long. I apologize for couldn’t supply all the waiting list this time. I roughly have 20 sets of FIFO KIT and dual XO clock boards in stock for now. All other items on the order form should be available. I thank you for your kind understanding.
1. I’ll follow the priority of the order number. But you have to send the order form back to me within 10 days. Or, it will be transfer to next one on waiting. All the rest will be transferred to a new waiting list.
2. You can also order I2S to PCM convertor board (I have enough stock), as well as other items available on the orders form.
3. Please let me know if you want to cancel your order, or you want to wait for next GB.
4. Your order number will be GBVFIFO + waiting list number, for example GBVFIFO20.
New items of GBV
1. I2S to PCM converter board V2.0 $79- USD/ea
Including:
- A finished and tested I2S to PCM converter board V2.0
- One 8" single-ended PH 2.0mm 10-pin PCM cables
- One 8" single-ended PH 2.0mm 2-pin power cables
- One 4" double-ended PH 2.0 mm 7-pin I2S bridge cable
- One 4" double-ended U.FL cable for MCLK
- Five jumpers
2. Silver plated U.FL coaxial cable
- 4” double-ended 50 ohm silver plated coaxial cable (gray) $3-/ea
- 6” double-ended 50 ohm silver plated coaxial cable (gray) $4-/ea
- 7” double-ended 50 ohm bigger diameter (178)silver plated coaxial cable for MCLK (gold) $6-/ea
Other items
Other items will be as same as GBIV, please see the order form for prices and availability. For documents and technical details, please refer for the GBIV post which was here:
http://www.diyaudio.com/forums/grou...-pdif-fifo-kit-group-buy-104.html#post3372684
How to buy
1.Please confirm you have already registered here on I2S to PCM board or FIFO KIT waiting list. Make sure your have correct order number.
2.Please download the empty excel GBV order form (GBVOrderformEmpty.zip) at bottom of this post, full in all necessary information in blue sections in excel, rename the file name by your order number and following by your Diyaudio ID(for example GBVPCM23_YourdiyAudioId.xls), then send the completed order form file back to me at: iancanada.mail@gmail.com
*Please double check and make sure the shipping address is correct and with a postcode, otherwise it may result in losing of the mail.
3. Once I receive your order form, I’ll send the Paypal invoice to the email address of your Paypal account.
4. Making payment by following the Paypal invoice.
Please do not send any payment to me until your receive my Paypal invoice.
Shipping and Delivery
Delivery via Canada Post. Please advice if you need a tracking number (registered) and how much value you went to declare the insurance. I’ll decide the best way of shipping for you based on maximizing the saving. Shipping will be in one of the following serves:
1. In an envelope (less than 100g) without tracing number and insurance:
To Canada: $2-
To USA: $3-
To other international places: $5-
*I2S to PCM board users are highly suggested using this service to make a biggest saving on shipping. Please make decision based on the safety record of your local post office service to avoid any possible of losing mails.
2. In an envelope (less than 500g) with tracing number and insurance:
To Canada: $12-
To USA: $17-
To other international places: $29-
3. In an box (less than 1kg) with tracing number and insurance:
To Canada: $17-
To USA: $21-
To other international places: $68-
Please note:
1. Please understand I don’t responsible for losing mails. If you select a deliver service without tracking number and insurance, you have to take the risk by yourself.
2. Please put correct shipping address on your order form to save my time on selecting the service of shipping for you.
3. If your Paypal shipping address is different from the one on your order form, I’ll ship to the Paypal address except you put a note of a new address on your Paypal payment form.
4. For CanadaPost, tracking number equals to register, no tracking number means it’s not a registered mail
5. If you know your address use to have problems such as customs clearance or losing of mails or etc, please give me a safe address in Canada or USA to ship to.
Payment
I accept payment in Paypal only. Please make payment within 7 days after your receive my invoice. I couldn’t guarantee reserving the KIT if you did make payment on time. I may ask you pay me in USD for this GB. I’m afraid I have to ask you kindly sharing the Paypel fee half and half with me as same as previous GB which would be 1.95% of the total.
Terms and conditions
1.All PCBs marked as finished are factory SMT assembled
2. Loop tested and bit-perfect confirmed for all items indicated as tested
3.Technical support by email or via DiyAudio R&D thread
4. No return as DIY KIT
5. Repairing service is for free within 1 year from date of purchase, buyers pay any possible round-trip shipping and parts. If KIT was damaged due to your reason. please kindly donate some money to my Paypal account to cover my labor. It usually takes me 1 hour to fix a board. Jobs will include trouble shooting, SMT reworking, testing and repackaging.
6.I will provide firmware upgrading service for free within 1 year from purchase, buyers pay any possible round-trip shipping
7.KIT will be shipped within 7 days after I’m getting the payment.
Some additional note
1. Please keep in mind including your order number for any service you need from me. That will save me a lot of time to recall your order history and information.
2. Please keep my address tag in case you need service.
3. Though I’m always trying to provide services as best as I can, but it may still not be able to reach all you standard. In this case, please kindly understand GB is not a commercial operating.
4. For small quantity prototype SMT reflow service providing by my SMTA supplier, the quality may still not as good as mass production. Dry solder may still chance to exist even passing the test. Inspection is required in case of having functional issues. Especially for those pins under connectors.
5. Some XLR socket may not be included on the S/PDIF board for it is too big to ship in an envelope.
Some useful resource
FIFO KIT R&D thread:
http://www.diyaudio.com/forums/digi...ifo-project-ultimate-weapon-fight-jitter.html
I2S to PCM board R&D thread:
Wiki:
Ian's I2S FIFO Project - diyAudio
downloading documents and information from GBIV thread:
GBV will be closed in two weeks. But now, the GBV is still open. New registers are still welcome before the closing time.
Enjoy you project!
Ian
  • I2StoPCMconvertorBoardV1.1.pdf
  • GBVOrderFormEmpty.zip
