F5 power amplifier
Anywhere from 22k to 220k would do.
47k is perfect.
I do not understand why some builders/designers use E96 values for components where tolerance is not a serious issue.
Matching of resistors is often a benefit.
But that does not mean 47.5ohms +-0.1%. It means match to +-an appropriate tolerance, but the components could be anywhere in the +-1% range and in many cases +-5% would not make a significant difference.
eg the emitter resistors in a BJT LTP could be specified as 100r
99r and 101r will make a small difference in performance.
But using 99r and 99r2 will be virtually the same as using 100.8r and 101r
The matching is what is more important. The absolute value is relatively unimportant. The LTP would probably work very well with 98r & 98.2r and probably OK with 105r and 105.2r
6L6
Moderator
Joined 2010
I'm afraid I have another question, a very stupid one: do I need those PCBs?
The only stupid questions are the ones you don't ask...
Do you need the PCB? No.
Will the PCB help make it easier and hopefully eliminate many wiring errors? Yes.
I strongly suggest using the PCB for the amp and PSU. It makes things simpler and the entire process will be easier and more streamlined by using them. :D :D
I assumed "KatieandDad" was a sign of father and daughter bonding over a common interest, and wished I had something like that with my daughter. She keeps asking me to build her things but shows no interest in picking up a soldering iron.
I doubt anyone has any problem at all with your interest in electronics, Katie. It is something that usually doesn't interest girls, and we are just a little surprised that's all. Happy to have you here and hope we can all have fun and learn something together.
"And what problem is it you have with us girls liking electronics too. Now you can see why I hide behind my dads identity."
I hope that's not pointed at me. My daughter raided the Accenture Corporate Management culture, braids and all, and is sitting just under the Partner level - as we speak.
All I can do is repeat an Opra thing -"You Go Girl !!!" :cool:
Andrew's detective work was the base of my comment.:magnify:
The one and only
Joined 2001
Over time I have run into examples of DIY F5's that were marginally stable
or perhaps a bit twitchy on the top end.
My own observations of the top end of the F5 with some of the full range
drivers was that it was a bit like "putting instant coffee in a microwave oven"
I went back to that recently and found that increasing the value of the 1K
input resistor to as high as 4.7K helps this, and recommend that people
experiencing overly bright sound or instability try it.
The resistance forms a low pass filter the input capacitance of the Jfets, and
takes the bandwidth down from the 1 megahertz region.
:cool:
