DIY Good Class D amplifier
d amp by Acca
With 1khz sine wave input signall,wave form measured at input pin of IR2184
Hi aleks,the voltage before the coil is 20 to 60 mv,but after a couple of minutes the voltage goes to negative value (-100mv ) and continue to it's negative reading,i remember this senario on class A amplifier something like (thermal run-away)but my output FET'S is in normal temp,less than 40 deg,my frequency set to 160khz any solution?hope to hear more from you.thank's.
d amp by Acca
Green at the upper part is a 12V indicator,red lower right osc. indicator,red on lower left OCP,blue caps for snubber if ever needed, by the way Aleks please post a schematic with feedback, how can it be implemented on this circuit?thanks.
Feed back can be make same as classic amp. (for example tda7294)
On SG IC you have op-amp.Try to wire it in inverting or noninverting op amp.Speaker + pole can be used for feedback,instead internal output of op-amp.Simple 🙂
Oh 90N20,90A 200V 😀 😀 😀
This can be music welding inverter 😀
those are the only mosfet, I have
and pure igbt
if it works maybe buy irb4227
the kicker amp uses 6 of these in single subwoofer IXGQ90N33TCD1 and are very power.
that's why I like this design in order to vary the freq. for use with these IGBTs.
and are not amp. welding if not for ears popping
thanks.
: Wave2s:: Wave2s:: Wave2s:: Wave2s:
and pure igbt
thanks.
I have almost finished this,only need ir2184 and toroid inductor.i couldnt find them
Is there anything wrong with using 3.3k for dc offset pot and uf4007 instead of 1n5819??:guilty:
mosfets are irfp250n :guilty:
