Hai friends i want to build DAC from lite audio , PCB DAC 38 , but i dont have schematic for these PCB so help me please,,? to fine this schematic is very hard to found the schematic DAC 38,,
I think is beeter to Firstly solder are IC processor and and DF 1704 PCM 1704K,, i want more coffe he he he
yups, need special time and more coffee and ciggarete,, he he heGood luck soldering DF1704
Solder shorter parts first...then when you flip the pcb over the parts that are not soldered yet will not slide away from the board.
Then next tallest, etc.
more than coffee & cigarette a lot of patient & luck😉
P.S. I soldered a couple....and if possible i will never again to do.
ha ha ha thats rigth ,,!more than coffee & cigarette a lot of patient & luck😉
yups dug, absolutely,,,! thank,,
yups ! the digital filter DF 1704 already soldered and can work by now,,! i am just have problem to found ic opamp SSM2122 for balance out put,
Now is thinking,,, how make unit lcd backlit display to displayed and indicated frame rate and sampling frequency information ,,,for my DAC ? how how how,,,??
Hey, I just inherited a 85-90% completed DAC-38 board
all I'm missing is:
CS8414 chip (X1)
74HCU04 chip (X1)
SSM2142 (X2)
EL2044 (X4)
and especially any kind of schematic...
can someone help me with any of those, all the parts are now obsoleted by mouser and the others....
I could probably find replacements but for the schematic its quite hard.
any help would be appreciated.
all I'm missing is:
CS8414 chip (X1)
74HCU04 chip (X1)
SSM2142 (X2)
EL2044 (X4)
- Digital Line Level
- Starting for soldering my DAC 24bit 96kHz PCM 1704 K
