Good solder station?
Pace is a bit behind the times. With the invention of the RF induction irons, heat up times are measured in 1-5seconds, with some like JBC, "overclocking" the iron to allow easy soldering even on heavy ground planes. The recent Weller series is a direct response to JBC, Metcal, Ersa, etc.
JBC example:
CD-2BB Digital Solder Kit
I've been looking at that station to replace my ancient Weller TCP. JBC was recommended when I asked my PCB assembly house. I like the fact they go into a lower temperature mode when in the stand, saves the tips blackening.
pico is €130 nano is €210. I keep reading the specs and cant find a reason to pay the extra for the nano. The nano must do something for the extra bread but what?
It's confusing indeed in their brochures. I think it may possibly lack the auto sleep functionality in its i-tool beyond having a cheaper lighter tray.
If the price difference is only due to the tray then its an absolute bargain. Maybe an email to Ersa or to a main vendor can clarify.
Both being small on the hobby bench with separate trays=good ergonomically. You need light silicone cable and a light handle. That combination frees your moves and precision.
https://www.youtube.com/watch?v=KHlM6vgfQxo
Check spares availability.
I am down to my last heater element for my station. Two blown in ~5years.
Only established brands available through established vendors will guarantee future availability of tips and spares. A major factor on deciding for Weller, Ersa, JBC, Hakko, OKI-Metcal etc. All those brands have an extensive catalogue of cleverly shaped tips. Their tips metallurgy is far superior to the bargain brands too.
Atten have a range of solder stations... Products / Soldering Tools_atten
These use Hakko format tips that are available in a wide range of shapes and are economical.
Additional pencils are available quite cheaply also...cheap enough to permanently fit different tips and swap pencils according to need/application.
Search Ebay for "Atten"....stations, pencils, tips real cheap, and perfectly good.
Dan.
Those are all Hakko 936 clones. They differ in build quality and temperature steadiness between them. Their price and Hakko tips compatibility format are their strengths.
The moment you jump over the Hakko FX category you get lighter handles and silicone cables, sleep functions, 10-20 sec heating up times, metal enclosures and trays, that kind of stuff. (The Hakko FX has a metal tray).
looks like the same solder iron used for some years in a BlackJack station
I don't know much about the US company Curcuit Specialists
but they appear reliable and always seem to have more or less the same stuff listed
and avilable from UK at 27GBP makes it tempting
and some of us does not solder so much complicated stuff
sure, I solder often, but mostly simpler things 😉
well, my loved gas iron is trash now ... with a handfull of new tips now useless 😱
The RS DS50 (your third link) seems to be exactly the same as the one Conrad Electronic offered in Germany years ago. I bought mine approx. ten years ago and it works still nicely.
I'd get that one. Although, keep in mind that a 80W version exists, maybe better buy that.
Rundmaus
I take it you mean the Ersa
yeah, 80watt sounds like a lot for that small iron
will it be able to solder a print mounted power supply ?
Those stations push power the more their sensor knows its going away so they maintain the delivery. If you get a 5mm chisel tip they will do OK on PSUs, ground planes, thick cables etc. for the hobbyist and semi-pro level. I have a 60W quoted Metcal and it really delivers with a thick tip on such jobs no problem. The good thing is that the Nano and 470 KHZ Metcal category offer a range of circa 10 Euro tips in average.
I bought the little Hakko FX-888 (not the D) a few months ago when my Weller solder station crapped out, and I have no complaints. It heats up quicker than the Weller, has a smaller footprint, and better look and feel, as long as you don't mind the garish Fisher-Price yellow and blue color. At least it won't get lost on the bench...
Any opinions on a used "JBC Advanced 2000"?
Excellent dynamic power delivery and thermal recovery. Its the same as the current ones, it just lacks the LCD display. Personally I don't like the integrated stand format. They usually come from professional benches when auctioned on E-bay like the Metcals, so condition is to be double checked with the seller. Hand tools and tips are professional level priced and performing of course. Just weigh bench space, condition, running cost, and power needs for your use. JBC soldering performance per se is champ.
