Hi there
i'm curious what do you say about this dac board:
http://goo.gl/RcrHel
anyone using it ? since i can't find any thread for it.
thanks for your replies
greetings
greetings
why is so expensive considering a 2,5$ DAC IC?
curryman's design is the most complex one I've seen around the ES9023 and includes also JG buffer on it's output and costs 40$ with all the components assembled; please describe what makes your board so special so that it costs more than a finished ES9018 DAC from ebay?
Τhe chip that alone can not determine the value of a device, the device was designed for six months with many tests, the final result is above expectations ,the other materials of board are first quality and expensive , just the u.fl connectors cost 6 euros from mouser , etc etc ..
unfortunately the final construction costs are quite high, so the final price can not go below this price
so simple thinks
if someone wants to buy,
if not
buy something else ,
cheers !
have a nice weekend !
so simple thinks
if not
cheers !
so simple thinks
if not
cheers !
I bought this DAC a few weeks ago,and i very very satisfied .
Better than the DAC2496 (AK4396) even modified ..... a low cost DAC 😉
Serge
Ηello my friend Serge , I'm glad you liked the mambo dac ,
please try to use a big good IE transformer in 6 volt and up of 4-5 amper ,
don't use torodial ,,
Vasili i want also one board, but today the damn bank closed 2oclock sharp and i didnt manage to add money to my card.. Monday i ll make the order.. the box and the transformer are already waiting!!
so simple thinks
if not
cheers !
Hello designer,
Can you post 20Hz, 2KHz, 20KHz waveform measurement at 0dB ?
Yes but ,, i don't post
But why are interested in the specific measurement in a default analog stage like the es9023 ?
can you chance the specify of the chip ?
if you can ,,, i want to now how
That means you are not the designer of this es9023 device, and may be don't know howto test a DAC......
i don't like the aggressive style of your writing,
so you can think whatever you want
cheers
and if you find the designer of the board ,, let my now !
cheers
It seems that someone copy & paste other DIYAUDIO members' hard work, and then sell high on the bay.
1 I'm not the designer
2 I do not know to measure
3 I'm a thief
you now I'm too old to play with a troll !
end by my , speak with your self !
3 I'm a thief
Guys. Why do you always have to use harsh language when talking to each other? We are all a bit "sick" with our hobby so lets keep it calm🙂
Anyways. I have also ordered one of those so here are my impressions and mods.
1. Its a nice piece of DAC but I will not call it high end.
2. It has a sweet sound but lacks "something" I normally run with a dual WM8741 in dual Mono config and the Mambo cannot match the quiet and airiness of that setup.
3. it is quite nice if you want to do a small dac without too many peripherials.
My listening setup was the same for both dacs, so after the dac chip there is a tube buffer. The WMs have an addition of Mundorf Silver/gold Oil caps to block the DC, these are not necessary with the Mambo.
Regarding power supply i run them both on the same DIY Ultra low ripple battery driven PSU.
So IMHO if you want High end go with something else. If you need a nice cheap dac without too much "extras" its a good choice.
I also changed the filter caps to silver Micas and used more decoupling on the critical places on the board, helped somehow but still a lot of road to cover to match the WMs.
- Vendor's Bazaar
- ES9023 dac on ebay
