Valve Itch phono
Thanks Salas I will use this schematic as per your advice,
I wonder If it would be possible to duplicate/mirror the circuit to make it balanced
Of course but you will never have the level of matching required for good CMRR with so loose tolerances that tubes will produce in open loop circuits like that.
To the contrary when using a balanced impedance primary SUT like the Jensen you automatically enjoy very good CMRR.
