Valve Itch phono
Its OK for the DL-103R bcs its 18-19 Ohm for real so the 977 primary loading is very near.
59dB total will give 220mV. Not for a buffer preamp.
BTW the Jensen JT44 at 10KHZ square before and after Zobel termination on its secondary.
That price is for a pair or each?
6K8 + 200pF dulled the leading edge too much for me. I ended at 100pF polystyrene for the picture I posted. But this is a test with longer cables so its possible to be optimized at 130-150pF in a build. And there is ear check in the end for each one's cart and phono.
You can. Its 600 Ohm like an MM cart.
Measure 200mV RMS 1kHZ on its output at 0 attenuation with the DMM on AC. Then select 40dB attenuation. Feed it straight to Itch without SUT. You should get about 280mV RMS on Itch's output for 43dB.
