An illustrated guide for Aleph 60 builders
short copy & paste orgy
i think about this
but will it work😕
To small sinks? I dont know? my calc was this way
2.22A bias with+/- 35V rails will be 155,4W per channel, +20% margin for all the other stuff makes 186,6W for one sink which have with 200mm min. 0,125 K/W maybe 0,1K/W
So the temp rise will be 23,31°C with 35°C room temp i will have 58°C Sink Temp.
so all seems fine and i have 20% margin in my calc, some i will need for rectifiers and the rest of the chassis will also dissipate heat.
so i think it should work-> or did i make a mistake and this all will not work?😱 ...dont drive me crazy:headbash:
and my question with the CRC vs C thing...
....my intend was this way i dont see any CRC at the org. A60 SM, at the first view no CRC at the actual XA30.5 and this all are
highly praised amps with only C PSU`s. and this makes me thinking...:scratch1:
you not... 😀😀😀
that is just not possible. rails * bias = aleph 60 is hotter.
+/-23-24V rails and 2A bias =92-96W (alephJ)
+/-35V rails and 2.2A bias =154W (aleph 60)
or did you meen one ch aleph 60 on the same sinks as 2 ch aleph J?
Oh, that was not correct what I sad. The fet temperature! That what I am worrying about now. Due to the lower dissipation/device. Dissipation of A60 was no doubt bigger, although I biased it a bit lower and rails were 32V.
