Tools:drill bits, hot air gun, crimper etc...
Here is the details of the shop I mentioned before. Drill bits of all sizes, hot air guns (Rs 350/-), MX crimper (Rs 300/-) and all kinds of tools. (Crowded and tiny shop.) Drill bits Rs 5/- a pieces (0.8mm, 1m I purchased).
Roushon.
Roushon.
This shop is only 4ft wide rightHere is the details of the shop I mentioned before. Drill bits of all sizes, hot air guns (Rs 350/-), MX crimper (Rs 300/-) and all kinds of tools. (Crowded and tiny shop.) Drill bits Rs 5/- a pieces (0.8mm, 1m I purchased).
Roushon.
Can you please post the approx. price.Just came back from Lohar Chawl (Mumbai). Attaching the details of a
seller I found accidentally. Copper clad board and PCB making other materials. Wholesale shop. But gave me pieces of board (FR4, 35micron), around 1 sq, feet sizes. He has long sizes (2 and half to three feet) and about 2 and half to 4inch width boards. Will give in wholesale rate. You may give a try. Also has other things like silver solder etc (minimum 500gm). The shop looks unimpressive.
Roushon.
Do they have post phenolic and fiber glass copper clad
I paid Rs 225/- for 9inch x 12inch, FR4, 35micron glass epoxy. He showed me
copper clad aluminum board also. You can call up to find some more information.
Roushon
hi guys
do anyone of you know where to get copper foil.used in smps transformer for shieding.
in delhi.
thanks in advance
ravs
The address in Mumbai (post number 760) I gave has copper foil, but it is of
no use for you I guess.
Roushon.
dear roushan ji
i etch this pcb but ur paper are not reached us yet
Well done! Sorry about the papers. It will reach definitely if the address you gave is OK. But
it seems you are doing fine without it.
Best wishes
Roushon
Best wishes
Roushon
dear sir i use only art paper.thanks ur ever masood my ideal
This is a great thread and thank you for all your efforts. Does anyone know if Tag Strips/Turret Strips like these are available? Yamamoto Terminal Strips
@Masood,
Here is a link for sale of LM3886TF for Rs 200/- each by nalinb80
http://www.diyaudio.com/forums/swap-...86tf-sale.html
PCb's for Rs 30/- each by rajudp
http://www.diyaudio.com/forums/chip-...ded-pcb-4.html
I think you can get it made in any Jewellery shop. Just take a print out and describe them.
Otherwise, it is very unlikely to find it in India.
Roushon
Tools in Flipkart: Dremel
Some interesting tools available in Flipkart including rotary tool from Dremel (Rs 9300/-)
Hand Tools - Buy Hand Tools Online at Best Prices in India - Office Supplies : Pens & Stationery | Flipkart.com
Roushon.
Roushon.
Press-n-Peel Blue is expensive $2 per sheet
Presensitized Positive Photoresist PCBs
Are they available in India
You may take a chance by asking Gautam (See post no 760).
Roushon.
- Design & Build
- Parts
- Parts in Mumbai (India)
