IRS2092 with IRFB4227 problem!
Good morning. Design and build the amplifier below and did not work.
Does anyone have some hint of what might be wrong?
Please contact me by email.
Thank you.
luizcpimenta@yahoo.com.br
Hi guys, its long time that I wrote here..
I have one question.. Is it posible that one 12V aux supplay with (on example) MJE13009 supplays two IRS2092 with gate buffers, and if it can, can u tell me calculation for resistor that i marked on picture?
BTW can enyone look at my project and tell me is everything allright?
tnx
It looks similar to one of my 2092 designs.
I didn't use the diode and 10k on my 4227 gates. I relied on 2092 deadtime at max.
The 1nf across the audio input is a bit odd, usually an RC is used if you want to get rid of RF. I didn't use an input filter and it worked fine.
The 2092's take upto 150mA so two will take upto 300mA into VCC.
You will need a heatsink on the MJE13009.
I dont understand, with half, 4mA current to base of MJE13009, on colector current will be lower, and I need higher current for two 2092
For one Rtip is calculated (Ucc-13V) / 8mA, so for base of MJE13009 current is 8mA for one 2092
If you half the resistance you will get twice the current.
Ideally you would calculate from B- to -12 volts and use half the max current into the zener and work out the resistor from that.
One more question.. I notice that ucd amp with IR2110 in half bridge operation has lower bass, not that strong but same amp in full bridge operation has much stronger and deeper bass. Is the same with IRS2092 amps or this amp in half bridge has strong bass?
tnx
