Adjusting EF tracking KSS-240a TEAC VRDS
Does anyone know how to adjust the EF Tracking on a KSS-240a Laser head in a TEAC/Esoteric VRDS-T1??
The Esoteric service manual isn't much help as it only states how to adjust settings on the Teac Servo board. I found a service note that talks about adjusting the Focus bias pot for the clearest eye pattern. but nothing about the EF tracking.
I replaced the laser assembly and adjusted the servo board as per the service manual. and the unit would play a cd but would skip badly once it got past track 9 or 10. I adjusted the Focus Bias pot per the service bulletin for the cleanest eye pattern and it got a bit better. but not much. then out of frustration i tweaked the EF tracking pot and it hasn't skipped since. I figure i must have it close at this point. but I would like to adjust it the proper way before buttoning it up.
In other service manuals I have seen section where you look at a specific test point and then adjust the EF while fast forwarding or fast reversing for even tracking above and below the zero line. I would assume something similar but I can find no information on the subject anywhere. even reading other VRDS service manuals. they seem to get less detailed in each one. some don't even state what track to use for adjustments!
Ok Stephen Sank's note here I think is really critical.
The other two pots on the 240 are EF balance & Focus Bias. The latter is correctly set by clearest, max rf pattern, but the EF bal can't be precisely set that way, often not even close to best. The best way to set EF bal on virtually any player is to put a cd on pause, then look at the tracking error output signal(TE or TER, usually). If you slow down your scope a lot, you will see the kick pulse, as the laser is told to jump track to stay on the same point on after each revolution. Proper EF balance is set by having the positive & negative going peaks of this pulse at equal length above & below the signal mid line. This is perfect EF, and is critical for proper tracking.
There's a picture of E-F balance procedure in lots of Sony manuals...see below. The basic principle is as you describe.
Is it best set at a particular point on the CD, such as half-way maybe? I don't know what's on YEDS-18. Note it says it (and the focus bias) should only need adjusting for a new mech, which I guess is why they moved the adjuster to the mech itself.
After an epic trudge through fixing every problem a CDP can have, I discovered my 101 has run out of adjustment on the E-F pot 🙁. Fine until the last track. I hate it when that happens.
well Track 1 of the YEDS-18 test disc is listed as:
01 - Air Glow-Theme of CD, emphasis on
while the adjustments in the VRDS T1 service manual say to use track 4
04 - 100Hz Sine Wave, 0 dB, L & R, emphasis off
I don't know what difference it makes?
Zc
A themed, impressionistic test disc...Sony is endearingly considerate at times 🙂
I don't understand, either. Does the alignment of the error signal vary, or does the player's tolerance of misalignment change? One or other reason must explain why later tracks are the first to suffer. If the alignment varies, then adjustment should be done half-way through the CD. If not, then it shouldn't matter.
AFAIK the adjustment is to the gain applied to either the E or the F photodiode, to make the peak amplitude of the two signals equal. This seems simpler than it is, considering that the laser head is supposed to move to make them equal anyway. I assume the head seeks equal area, rather than equal amplitude.
Misadjustment leads to physical misalignment. The signal remains centred with respect to area as a result, but not with respect to amplitude.
Even if all this is true, it still doesn't directly explain the symptoms. As the CD plays through, the curvature of the track reduces, and so does the average rate of radial movement of the head. Why should either make a difference to the E-F balance, or the player's sensitivity to imbalance?
Anyway, the sure option would be to adjust half-way through the CD.
The VRDS service manual has a section on adjusting the Focus Gain adjustment. using track 4 (100hz) inject a 1.05khz 10V P-P signal into the FE2 pin on the test connector through a 100K resistor. then observe the signal and the FE1 signal on a dual trace scope and set the F.Gain so that the phase of the 2 signals is 90 degree's apart.
The Tracking gain is similarly adjusted injecting a 1.09khz signal into the TE pins.
So I have no idea how or why the 100hz signal on the disc has anything to do with those adjustments?
Then I found a separate service note about adjusting the Focus Bias pot on the laser block. but there was never any mention about adjusting the EF pot. and my unit would not track the last few tracks on a disc after replacing the laser assembly. Tweaking the EF control has fixed that problem but I need to get back in there and adjust everything correctly.
I found a local service dept friend that will lend me the TEAC MCD-111 disc so I can do the adjustments per the service manual at least.
Your symptom does NOT suggest a servo misadjusment fault at all. It is much, much more suggestive of a mechanical problem. First check the obvious- drive gear teeth, gear axle grease hardening, guide rail lub, cable interference. Then check that there is no warpage or other defect in the guide track opposite the rail or with the rail mounting.
As for the adjustments, it does not matter what disc or where on it that you do the EF/tracking balance, unless the disc is just plain defective. On the focus & tracking gains, IGNORE the manual. The best way to adjust, which I've written here on other threads, is to turn each gain down(i.e., less coil noise), while playing a known good disc, any good disc, until you see the RF waveform start to collapse, then turn gain back up about 1/6 to 1/5 of a turn. Focus bias/offset just requires going for maximum height and clarity of RF waveform on ANY disc. Tracking offset can, most of the time, be done in stop mode, just going for 0vdc on the TE/TER output test point, or can be set during my noted-above EF procedure, simply planting the average center line of the waveform on 0vdc line on scope, with scope in dc coupled mode, of course.
Honestly, I don't know of ANY cd player/transport that actually requires a proper test cd to do proper alignments, and I've been in cd service for as long as cd has been around. I have not used a test disc since 1984. Literally.
The only special tools generally ever needed are the optical laser power meter(e.g., Leader LPM8000) for laser power adj., and an accurate >/=10mHz frequency counter for VCO adjust(rarely needs adj on most players).
I can't see how the frequency of the signal on the disc is significant. More likely is the position of track 4? Phase difference at a particular frequency is a measure of delay...the reaction time of the control loop. I wonder why the focus and tracking frequencies are so close, and yet not the same. Curiouser and curiouser.
I generally end up going through all the adjustments at least twice, and then tweaking the focus gain to minimise mechanical noise from the head, but I've never worked on the later types with adjusters on the mech.
I've learned to appreciate the old Philips single-beam, swinging-arm system.
Your symptom does NOT suggest a servo misadjusment fault at all. It is much, much more suggestive of a mechanical problem...
Generally I agree, and respect your experience. However, my CDP101 definitely begins to skip on later tracks when E-F balance is misadjusted. It is especially prone to suffering drag from cables to the head that can cause similar problems, so I've been scrupulous in eliminating that as a cause.
It is quite possible that the problem adjusting E-F balance, and the skipping, have a common cause, like storks and babies. However, when Zero reported that adjustment cured his problem, I'm happy to suspect a direct connection. I guess we'll soon find out.
and keep in mind this is a brand new laser block that had never been adjusted to that transport! When I put it in, I cleaned the slide rail and inspected the gears. the VRDS system has one gear that's prone to go bad and my gear had 2 teeth that showed stress so I replaced the gear and a cleaned and lubed everything.
It was consistent. track 9 on a cd I have has a defect that most cd players hit, burp then keep on playing. this transport would hit that blip and slide to the end of the disc like a needle sliding across a record! Other cd's would track fine until the very last few tacks and then start skipping. the EF balance definitely fixed that problem and now i can play any disc or CD-R even the notorious track 9 disc without even a hiccup! I just need to get back in there and adjust it the right way and make sure I have it set correctly.
I am traveling today and wont be able to get to the shop until next week...🙁
I have replaced over a hundred KSS-240 laser assemblies and being supplied direct from Sony for Sony players, have never had cause to adjust the pots and they are usually factory preset and sealed by Sony.
Maybe you are describing the setting up of a pattern part?
I strongly suggest you use a laser power meter of your laser may die sooner rather than later!
I was able to borrow a Teac MCD-111 test cd and wow watching the laser i can see why these are special. the laser hardly moves in any direction at the very edge of the disc. so it is very concentric! the tolerances are very tight.
I adjusted the servo board per the service manual and i was pretty close. it was much easier to adjust as the disc jitter was very low so the signal was more stable.
I should have re-checked the kick signal. I didn't and I think I had the adjustments just a touch better before tweaking with the test cd. I have one cd that has some sort of manufacturing error in track 9 and it causes most cd players to skip or jump at that spot. this unit hits that spot and looses its tracking completely and had it a bit better before. The tracking gain adjustment seems to be the touchiest!
So...I will have to crack it open again and check the kick signal and if it is still right on. then tweak the Tracking gain a bit more as it had been playing the dreaded track 9 just fine with just a tiny skip in one spot.
DIY Test Disc....
An old servicing trick/tool is to carefully cut a wedge shaped strip (0.0 to 3.0mm across the width of the tape) of matt black type insulation tape and stick it on to the playing surface of the cd...about mid disc is fine.
When EF balance is correct the defected region should play right through...error correction should take care of the audio dropouts.
Dan.
You can use standard shiny insulation tape if you blacken the surface with a black Nikko Pen (Sharpie) or matt black paint, before cutting the wedge shaped strip.
Well my adjusting woes continue. I borrowed a MCD-111 test cd and set the player per the service manual. and found it was a bit worse then what I had tweaked it to. I found that the Tracking gain liked the be set at less then 90 degree's for best results. So I went through and redid all of the calibrations with the test cd and got it to a point where it would play ever cd included my dreaded defective track 9 disc just fine.
So i reassembled it and it would skip like crazy. what the heck, take it apart again and it worked fine. after much dancing with covers I discovered the shield that goes over the servo board causes the player to be WAY more sensitive to defective cd's...which makes NO sense at all! If I remove the shield, it plays fine. put the shield back on and the slightest imperfection in a disc causes the player to skip then loose the entire disc tracking and stop, or spin way up in RPM and just sit there. each time If i press stop, then play again it will then re acquire the disc and play for a bit before skipping again.
Now what exactly the shield cause me messing with I have no idea. I don't think it is heat build up as nothing is really that hot.I am inclined to just leave the damn shield off!
Grrrr. Maybe i just got a bad laser assembly?? I have a used one I salvaged from a working 5-disc sony player, maybe I will swap it out and see if it operates in the same fashion.
I think, yes. There are many laser units for replacement parts from China - not only this SONY modell.
I discover for several years this supplier - there is still mentioned, whether it is a genuine part or China copy - go to
N-tronics Elektronische Bauteilen / Electronic Parts - N-tronics GmbH is a creative, independent, global stocking distributor of semiconductors
