Is it correct that for a stereo VSSA (LC) amp +/- 35V, one PSU board is sufficient? In that case one PCB is sufficient for me. Else, Two Boards. Sorry for the misunderstanding.
--gannaji
I put you down for 1 board, and you can always change your mind later.
In my opinion, w. 35V supply rails (which is what I am using), one power supply is enough, even at fairly loud listening levels, assuming a normal room, 8-ohm speakers, recommended bias, etc.
With a clean power supply, VSSA sounds exceptionally good, and does not require a huge amount of reserve power. This applies even to the very first and simplest version I built from Shaan's schematic. I tested the influence of the power supply, by comparing to an old adjustable linear bench supply from Tektronix. This led me to the capacitance multiplier approach.
If you expect to run your VSSA at the limits LC specified, or speakers which represent a "difficult" load, then you probably need two, as he recommends.
It basically comes down to how far the DC voltage will dip during heavy bass passages at high volume.
The other reason to use two separate supplies is if you have the kind of no-compromise sound system and listening room that LazyCat used in some of the VSSA tests. Using separate power supplies makes the two channels independent, so with the right listening room and
very good speakers, it will enhance what people refer to as "soundstage", depth, separation of vocals from background music, etc. That kind of sound system takes a lot of money, or a lot of time, or both. I get speaker envy any time I look at the pics of his listening tests! (some of the speakers LC was testing with cost almost as much as my car...
