VSSA Lateral MosFet Amplifier
VSSA is running since 2 hours non stop.
I placed it in my current setup
- Philipps CD723 as drive on digital output
- TDA1541 DAC
- Preamplifier DIY UGS : ugs - audiyofield
- DIY Bookshelfs speakers (Troels gravesen project) : lifa - audiyofield
My listen room is in my basement house. It mesure 15m² and is quite good for bass reproduction.
Some pictures :
- 1 : Cinch with + and - soldered for adjuesting session
- 2 : Vas bias and offset adjusting
- 3 : ouput bias adjusting
- 4/5 : VSSA in my listening room
So my version is Crappy one : no hightech aluminium box, really crappy heatsink, no SMSPS or capacitance multiplier, non CRC nor CLC, no hightech rectifier diode just a 300Va 2x25Vac per bloc coupled at two 35A rectifier bridge, and follow with a good 22.000uf/40v screw cap per rail....
And even with no breakin this puppies are terrific...I have as many people my fetish music stuff that i listen more than 10 year long and that give me right some flags on what the system is capable....I say you these puppies are unbelieveble : details of course, bass line (grrrrrr dry as they must been but deep...and i have only a 14cm woofer...). One thigh that suprise me the most are the weigh of silence...it's quite diffcult to explain but when more time when sound is not so clean even during silence you have impression that somethings playing....
These puppies must yet take more breakin and me more pleasure time. Thanks LC for this present.
Marc
Goood you like the first impression. I tell you this little amp show all the details from the background, ussually people just think that there's maybe something more in the music to be revealed, and now comes with ease in more natural way to the listener. :yes:
For me the most flashing feature is the clean reproduction that let you hear every sounding stuff in a reproduction...
Marc
LC will you provide a Diy schematic for the further project (lat fet double die) that we could produce for us selves at house?
Marc
Probably the First One will be just a commercial module, it has to have the cutting edge and to be better than VSSA in all respects. If I will fail to fulfill this criteria than I'll make it public. First I have to design PCB, make stereo amp and go through listening tests, so still long way there.
Can tell you it does have some features not to discuss further here but still that means nothing if on the paper only. 🙄
Ok. When ALF08NP16V5 are allready available on farnell i think i will try my VSSA 1.4 single layer. Could you point exatly were TP1/2/3/4 are on 104 version?
Marc
I know you have many different units in your system and you know all combinations and how it should sound right, so it is always interesting to insert some new equipment and see if there's any improvement or not. 😉
My first DIYamp was a 5Ch latfet current feedback one ( zenquito : 2A & DIY, quite good but for sure not VSSA level competitor...Some 10 years old pictures under from the amp
Nice job 🙂
I have Troels loudspeakers too - CNO...more than happy with them 😀
Could you tell more about your UGS preamp? Sound? Matching with VSSA?
It's a quite difficult exercise as CheffDeGare is a friend off mine and as i was in UGS project the first beta tester of different version that achieve to final UGS module. As the complet preamp (with remote....) stay 95% unifinish, it's the proto02 in crappy form that is more than 5 year running since.
The whole feature/personnality of UGS is that it has no personnality : extremely neutral, it play what's exist, in that it's for me a good friend for VSSA. Before UGS i had a tube pre and these was all but not neutral. The first switch to UGS was desappointing🙁🙁🙁 but after time the return switch to tube was not possible. Sound was as an over maked up women...not to see without make up or you risk to be affraid....:gasp::gasp::gasp:
VSSA PCB set - additional group buy
Hi all present and future GB members :wave:
Since there are requests for VSSA PCB modules on daily basis, I would like to give opportunity to new GB members to get their own VSSA amplifiers. :up:
As you all probably know I will receive 110 pcs of ALF08NP mosfets so I can guarantee additional 70 VSSA PCB sets to become available. 36 out of 110 are reserved for GB members listed below. 😉
So please list your names below and after the first six members. :yes:
Good luck! :cheers:
BYRTT 8 PCB set
CaféNoir 6 PCB set
ColinAlex 8 PCB set
DavorXXL 6 PCB set
DuffyDawg 4 PCB set + 4 SMPS400
electromf 4 PCB set
