simple solution for VU-Meter
Apparently, your meter is not very sensitive. You can improve the sensitivity by using a 1N34 (or similar) germanium diode to feed the meter rather than a silicon diode. Silicon diodes do not conduct until there is about .7 volts across them. Germanium diodes will conduct at a much lower voltage.
You can improve the performance even more by using four 1N34 germanium diodes in a bridge configuration to feed the meter.
Other than that suggestion, you may need to build a buffer stage to feed the meter.
It's possible to build such a stage using a transistor or two. It's easier to use an op-amp.
So.....I could have used the original one-trans. circuit (s.Pic) had I just fed it from the output? I think I' ĺl try the germanium diode first.
Happy July 4!
P { margin-bottom: 0.08in; } I tried a 1N60 (1N34 equivalent) diode, meter registers a little earlier but the sound still needs to be turned way up. I'm going to try a bridge with 4 x Schottky's 43/46, they're low-voltage similar to 1N60. Ordered online, wating...............zzzzzzzzzzzzzzz.................
Well I've tried the diode bridge, it didn't bring any improvement, meter still only registers at high volumes. Could you possably point me towards a very simple op-amp circuit that works on 15 volts, no negative rail. I don't need complicated circuitry to calibrate or anything else, as long as it registers at a reasonable level. Much obliged
I used the schematic from Rod Elliot (VU And PPM Audio Metering).
You can control the output level to the meter.
As stated on the article you should use germanium diodes. This was the hardest part since they are almost unavailable. Buerklin has OA95.
For the meter I used the Nissei TN-73-HS. They are large, integrated led ilumination and good aspect.
For the circuit I draw the layout of a PCB. I used the Rod Elliot circuit added with power supply regulators (78M15/79M15) and the led supply.
Works ok on my First Watt F5 Turbo. I adjust the output to 0 level at 1W. This level is ok for nomal listening.
I have not read the entire thread so I do not know if this has been offered to you, yet.
OK, here is what I did:
A double OP per channel, dual supply, active rectifier, time delay, and buffer.
As simple as it gets. Cannot be used for any serious measurements, pure eye candy.
Are you up to the task of converting it to single supply?
The needle moves up quickly, and down slooowly.
I salvaged my meters from an old Sony tape deck.
And to restore my honor as a serious diy-er:
This was a project a did for a friend - it is not in any of my equipment.
  • VU-Meter01.pdf
