DAC-END R (ES9018) full assembled board
I'm concerned about the reports of edge damage.
Even with a layer of bubblewrap, the corners of the chassis are too close to the outer edge of the cardboard box to be considered properly protected.
There needs to be additional space around the chassis, just 1 cm would be OK ... the cardboard box needs to be larger.
DAC-END R (ES9018) complete
you have purchased the following items:
1. - DAC module assembled and tested with all componentsfive shunt regulator
2. - DAC controller assembled and tested
3. - Chassie
4. - Transformer 2 x 6-0V 2A + 4 x 18V 1A or 2 x 9V 2A + 2 x 18V 1A
5. - Output stage, only passive I/V
I will be assembling, finishing and inspection include the following:
1. All Input and output connectors
2. 4 x opam 2134 for IV
3. installation of parts, inspection and finishing
4. one year warranty for all finished products
5. shipped to you.
Your job: pay me $ 150 for installation costs,
and freight (if you have not already paid), to receive it and enjoy the music.
quanghao
Hi quanghao,
I received DAC thank you.There isn't any cosmetic problem .
But i couldn't see opamps and any Input and output connectors ??
Amanero unassembled.
I paid extra 180$ for them am i wrong?
Thank you
Hi quanghao,
Did i paid extra 180$ for them am i wrong?
Thank you
And other cableing is not ready.So you mustn't test it.
Hi Audiodesign and Quanghao,
- When I click "Mute" the DAC shut off correctly. This is OK.
- When I press volume controls on the front panel or on the remote I can't get 0%. The lowest value is 1%. This is a problem because the signal does not shut down completly and stays at a level which is quite loud : I can hear the music everywhere in my house... 🙁 🙁 🙁 This problem occurs either on Coax input or on Optical input. I didn't try yet on USB and AES/EBU inputs.
What can you suggest to me ?
My "build" - unbalanced direct out. I am planninng on replacing the toroid with an r-core transformer. The DAC seems to be very sensitive to power line influences. When I switch the bathroom lights the DAC looses the lock for a second. USB only so far.
The sound is an improvement compared to the Musical Fidelity V-DAC II which I was listening with for a year now. A very noticeable improvement in bass.
