I recently used that technique with a 4,7u Alu oil shunted with a 0.012uF K71 (ussr styroflex) with outstanding results 🙂
Wich Alu oil are you using Ricardo?
Ok. Justo aged to got rid of noise on the simple series regulator.
Now I am back on business and ready to have a more fair difference.
If now I will recuperate the extreme transparency I had with shunt this is going to be the overall winner.
I will post listening impression later.
But who knows wich is the best system integration or better how to know the best system integration?
Priorities. Like what is the main thing the load needs. It has low PSRR and steady consumption but wide bandwidth? Better see to have least self noise and EMI than widest and lowest Zo reg. Don't use high gain in the error amp, filter the Vref more, terminate with a medium ESR electrolytic.
But I don't have much circuitry & lab knowledge or fancy test gear you may say, how do I optimize?
Use your subjective experience and common sense is the answer.
In your case you got EB series and various shunt regs around for instance. Apply one after the other, gather some idea of how they affect the music. What characteristics you need to push more? Tweak CCS if any, Vref filtering, termination if any, connection method and distance, parts quality, the pre-filtering or just the raw DC components, whatever you can tweak.
Keep a simple reference point. Like an LM317T. Is it getting any better than the standard chip reg? If worse, something's going wrong. Maybe interference with decoupling on the load's rails? EMI? Bad reg choice? Better shielding, grounding, etc. etc.
Here is a great idea how to "listen" to a power supply.
Simply connect a speaker or headphone after the supply.
Be sure to AC couple or you can destroy your speakers or headphones.
That is how I do it 🙂
Why did you never tell me, you trickster you ? 🙂
Here comes more good news :
LT4320/LT4320-1 - Ideal Diode Bridge Controller - Linear Technology
I did not see credit in the guide though.😛
The general architecture is following, especially in the parallel part. Which is different in open loop parameters and biasing. The CCS in yours is BJT CV+CC, i.e. much different.
Its very easy to change everything with just values, imagine what happens with secondary differentiations and other parts choices.
You can have the same reg with two different loads described harsh or dull. Difficult to strike balance for a general apps shunt reg. System integration is the key.😉
That's what I said (earlier), the CCS is very different 🙂 I was not saying that the regulator was the same, just that the shunt part is largely the same. I do recognize that both parts are part of the system.
I use Mundorf Supreme, Ohmite Audio Gold or Welvyn W22.
I certainly like wirewound and would not use a matalfilm or MOX resistor in speakers.
For me they sound kind of sharp.
I used Welwyn subjectively very good sound but are magnetics. Mills do not sound sharp: sounds very natural more than Welvyn.
I never tried the Mills but was a bit disappointed with the Isabellenhütte.
That was a long time ago and i may try them again.
Can you hear Mozart?
Good luck listening to the Shunt when noise is on the order of 50uVpk-pk!
That certainly needs amplification.
I just build a headphone amp that could do it.
Merlin, Mundorf Supreme are 20W Ohmite Audio Gold.
You can of cause parallel two 5W for a 10W.
When you have a good source they are quite affordable.
I even found a 10W at Mouser :
AG10F1K8 Ohmite | Mouser
Yes but Mouser only have 1K8 value😡
For OhmiteAG I only know thie web site but values only 0,10R-2,70R 5W
Ohmite Audio Gold non-magnetic non-inductive - hifituning24.de
Do you know other seller with more values?
No, sorry.
I think Mundorf is more or less the only company that sells them in quantity.
Somehow this resistors have failed on the market badly.
That is a pity.
That is a pity.
Joachim the pre-pre have enough gain for my Denon DL103R (is that I was looking for🙂) but I need to change all the resistor because are cheap/bad 1/4W carbon, the sound is very promising. What resistor do you recommend?
If you need even more gain you can double the 220 Ohm resistors to 440 Ohm.
That also gives you more dynamic range ( 6dB ).
For prototypes i use the cheep Yegeo 1% metal film resistors from Reichelt.
When it does not sound good with this resistors nothing helps.
For a slight warm sound i use various Dale resistors, the brown one.
Bigger size is better, so i prefer the 65 series from Mouser over the 55 series from Schuro ( way overpriced ). Most of the 65 from Mouser where anti magnetic too.
Super expensive and some like the cleanness they bring : Z- Foils.
I only use them, when the customer specifies. Other specify vintage Shinko tantalum.
There is also a new Audio Note antimagnetic tantalum i did not try yet.
The sound of tantalum ? I do not know, i try to avoid hard to get exotic stuff and i hate to make the AN head honcho even richer then he already is.
In my next link i show you the resistors i found the most neutral, not there, sound.
These :
Vishay - Vishay Beyschlag - Vishay Brands
use the biggest size : 0207
the 1% version you get at Distrelec, the 0.1% precission are distributed by another company i forgot the name of, you can google it.
The high frequency type is non inductive. Do nor know where to get them and not imprtant at audio frequencies. This is more the Giga Hz stuff.
- Analogue Source
- Masterpiece
