Thanks, sorry If I sound a bit impatient at times im just eager, do appreciate the help!
yes if i connected +PGND and -PGND it would be good however what I find hard to get my head round is that my transformer only has 3 wires on secondary so i presume i cannot actually make that previous circuit and will have to use Single Graetz as only option
or
this circuit which with 2x24v would be too high voltage anyway, this is preferred to me by far but a shame as the output voltage would be too high
Why would this give you 42Volts? The transformer used above is 2 x 25 Volt and gives an output of 35 volt ( without load ). So with load ( I calculate factor 1,305 always) and 2 x 24 Volt it will be around 31,5 Volt....
Yes, it gave me the voltage I needed thanks 32v x 2 so I wired up this new point to point PSU with bridge rectifier and bang...
no the amp didn't blow up but I still had a ground loop! exiting! lol even when the right channel was almost total disconnected apart from the earth and RCA input.
So yeah same problem when both RCA are connected Hum, so here we go take 3 Time to mess with the grounding further! my insanity levels are being pushed perhaps that's a good thing ?
PS: its not as stressful if the project your making is for yourself! this ones for a friend and long overdue, £800 in parts, nice price that
67 DEG heatsink
75 DEG washer on Mosfet
Bias 60mv or 0.06v across R1, target is 0.3v ! how the hell can i reach that lol
Any comments on this ? am i reading something wrong and have biased it way too high ?
That temperature is freaky at such low bias. by the time i make 0.3V across R1 this amp is going to be fried!
The heatsinks are massive!
That's for 2 pieces I believe (a couple)
That is some price for a single piece of bent plated steel.
Quick question as were are talking PSU right now:
Is is worth going through the hassle and doing a "quasi"-dual mono ?
By "quasi" double mono I mean using one transformer with 4 secondaries and wiring 2 each per channel using 2 bridges per channel.
4 Bridges total.
You can, but that transformer will run hotter and not cost that much cheaper than 2 transformers with the same combined VA rating.
yes it is so €6 pr pc for the 400mm parts.
4 Bridges total.
yes. there is not much more cost. and it can do wonders from what i've seen. the noise issues are less with dual bridges. at least with single transformer.
Im aiming for F5T V3, I have several matched pairs of Jfets at 7.3ma. Is single pair will be enough for V3 (cascode version) or there is a need to parallel (make use of Q1,Q2,Q3,Q4 slot)?
Don't use those precious JFETs in the cascode transistor position, rather use a normal BJT and save those JFETs for other Pass goodies. Use those Toshiba BJTs that Papa mentions in his article. I think it was the 2SA1837/2SC4793 complimentary pair.
How do I know if my ground loop problem (left input in only no hum right input only no hum both inputs hum) is not actually oscillations without having an oscilloscope ?
Im about to rewire the whole Power supply for 3rd time in hope of getting rid of this intrusive hum.
Yes It will not be used. Cascode transistors are marked as Q5/Q6, I will used 2SA1837/2SC4793 for these. Im referring with Q1,Q2,Q3,Q4 which is a parallel jfet slot. BTW im referring with the store PCB.
Yes.
Hi Buzz,
Is this referring to my query?
Does it mean im good at 7.3ma parallel pair or single pair?
Lets say 45V rail voltage.
Cheers.
I think a single pair is enough, in my F5Tv3 I also use a single pair around 8 mA, and they self bias around 5,9 mA in circuit.
Hi Walter,
This is great information. Have you change the value of R5/R6(V3 Schematic)
to 2.2K or you stay at 1K. Just making sure for me to avoid rework.
BTW, what is your rail voltage for your V3?
Cheers.
- F5 Turbo Builders Thread
