VSSA Lateral MosFet Amplifier
I set firmly the values since these are calculated and very important to consider. Also 10 uF MKT is of utmost importance to be in the circuit, tested at MHz bandwidth region. :yes:
Above applies also to the PSU local (PCB) capacitors , I'm talking about those 1000uF ???
I mainly use Panasonic FR nowadays. They have the same low ESR then FM but have double the life span. They are very affordable and i can get them from Reichelt in a day.
I used FR in my poor-man's through-hole version of VSSA/PeeCeeBee.
I hope to compare to LC's boards within a week, using the caps he recommended. I try to follow directions first time I build someone else's design, on the theory that making changes before having anything to compare is a bad idea, at least for someone with limited knowledge (tested that theory thoroughly... 😀)
I have noticed far bigger dependency on power supply quality than what I expect to see using different on-board caps (assuming similar ESR etc).
Measuring an FR 2200uF 6.3V for ESR in circuit on Paradise phono gives 0.031 Ohm which is usually 0.01 less for this instrument if measured off circuit to grip the leads better. (Went there if I firmly pressed the crocks down in circuit also, 29C ambient). That one ties with the 0.020R 100kHz 20C for its 20x10mm size can @6.3V in Panasonic's datasheet. Reliable data.
Nice toy, I am jealous! 😀
Salas! I have seen a few "different" MESR-100. I think yours is the latest one. I saw one of this meter open and I saw TWO ELECTROLYTIC caps inside. I am not sure if your is the same, but if it is...I would measure them to make sure those electrolytic caps are still good. imagine an E.S.R meter with bad caps! That MESR-100 E.S.R meter looks way better build than those "ATLAS" plastic toys meters.
but then, in 40V series you can get some pretty nice and big longlife 22000uf at ok prices
4x 22000uf per channel ?
I guess it is a trade off. but remember the more parts you put...the more are the chances they can go bad. in my case I would not use more than four caps for the power supply, as long as they are good quality and low E.S.R...all will be good!
PS: I always use Mundorf audio grade caps in my power supplies. They are excellent!😉
Capacitor dimensions for VSSA PCB:
- 10 uF/63 V, MKT, Vishay-Roederstein, 2 pcs
Lead Spacing: 15 mm
External Depth: 8.5 mm
External Height: 17.5 mm
External Width: 18 mm
Regards Lazy Cat :cheers:
I am searching for the MKT and I find this Vishay-Roderstein, MKT, 10uF 63V on Mouser's stock list: 75-MKT1822610065
Lead spacing is 27.5mm much larger than your spec. Can you point me to the one you used?
Thanks.
Well I have been watching closely - this is a fantastic result (amplifier design and pcb layout) LC. You kept it simple in layout and in physical form. I know you promised that you'd do this but it isn't easy and it turned out very well indeed.
I think this has turned out to be the 'F5' of the SS forum (meant as a compliment).
The LatFET is so well suited to this topology because of the ease of thermal compensation and ease of drive. The two-in-one package for the FETs was really the icing on the cake.
