Quick question. If going with one XO on the clock board, I still need to populate the CKSEL parts and a jumper between pins 2 and 3, right?
Not necessary for single clock setup if XOs have internal pull ups for Enable lines. e.g. CCHD957, Si590
Cool thanks. It looks like the Fox XO I'm looking at from the expresso line has internal pull-up for E/D.
Synchronous Re-Clocker for Amanero
I am planning to roll out a new model by combining the Master Clock, Re-clocker and Isolator cct all onto a single board. It will specifically target the Amanero with FW update to take external clock (22.xx/24.xxMHz). Ref: App Notes, Full Sync mode. The external interconnects like RCK and CKSEL are now integrated on board with short traces and layout optimised. The Amanero unit will plug on board as shown to form an enhanced USB-I2S DSD transport
acko, it would have been even better if the amanero was stacked above/below the reclock board, to make it more compact. also if possible - the smaller board the better.
Not finalized yet, especially the dimensions. Of course trying to make it as compact as possible
I like it! Compact is all well and good, but performance should be the primary goal. Hmmm...to build up the discrete boards on hand now or wait for the optimized/unified board?
BK
BK
BK
Limited discounted offer + free shipping for current users and a free board each for those who helped with the testing and evaluation, thank you🙂
One of the many reasons we all love you, acko
BK
BK
I was thinking about that too, because I haven't built up my AKX302, yet, then I realised that I can now build the AKX302 for a single clock freq and use the discrete boards for asynch reclocking and the revised board for synch re-clocking.
New board looks good Acko! I agree with bk856er, board size looks good and compact already and keeping physically away from the Amanero parts helps keep the sensitive part of circuit away from the noisy CPLD/. To go any smaller you'd be using quad FF and probably 4+ layer PCB to get all the signals in/out of the quad FF.
Agreed! I'm continually impressed by you productivity and work product. Then you add the occasional 'deal'.... Awesome work Acko!
glad Acko is getting some more public recognition for what he does these days. Acko FTW!
hsi68: What kind of XO board is the T-clock you have? 🙂
The T-clock made by Korean DIY society recently. Actually, its purpose is supplying accurate clock to Alix 2d2/3d2 MPD board.
The T-clock has the following characteristics.
Ultra low Jitter, Zero PPM, and 4-ch programmable.
Can't find. Please linkThe T-clock made by Korean DIY society recently.
Can't. Please linkThe T-clock made by Korean DIY society recently.
zero ppm hey? sorry ... that can only be marketing
OK its using something like Si5338, yes zero ppm seems to be more of a marketing term. it relates only to programmable frequency setting resolution, not jitter. its not clear if it even applies to any type of long term frequency accuracy, just the setting resolution
still an interesting part, not sure if thats the exact one used? but the Si5338 has period jitter of 10ps with LVDS mode, it states it could be higher (means it is) with single ended output. handy, but not the last word in jitter. which part is your board using?
Latest preview. Priced at USD 25 +shipping, board only.
For those who have already purchased the discrete re-clocker board (S01/S02), discounted offer of $10 and free shipping-offer limited to 1 board only.
A minimum quantity to cover fab cost required before proceeding. GB List
- Group Buys
- Amanero Isolator/Reclocker GB
