DAC-END R (ES9018) full assembled board
Hi, my dac works, i only tried it with amanero usb.
Have some problems :
1. If i plug the usb cable first and i turn on the dac, the lcd display shows weird characters and i shutdown the dac without try to play music. But when i turn on dac first and then connect the usb cable the lcd display show normal.
2. About the button, is the center one for mute or standby the dac? Because button function for center and right ones doesn't meet with what printed on the pcb.
thanks
Nicko
thanks
Nicko
Hi Nicko
Please see Post: #634 for functionallity of Remote and buttom.
Br
Caad
Hi guys, halo, congratulations you got the DAC and run it.
The remaining friends, including the DAC + power transformer ....
I need to do the following to ensure the transportation and the best for you.
I am alone, just the kids just do these things, but very hard but fun:
1. all mounting screws on the bottom
2. installed power transformers
3. mounting screws on the front
4. installation screen controller
5. DAC board assembly and packaging shell +
You see attached picture
Thank you all for your trust.
A dac running is a pleasure for me!
thanks
Nicko
How you are using the Amanero module ?
The DAC module have a jump to set external power supply for Amanero mdule but to use this configuration it is necessary cut a pcb wire on Amanero module.
I suggest to do this, here the photo to this operation.
Sorry probably I forgot to give info on this.
