Alea jacta est.
The die has been cast and it looks nice but victory will be only after the hot iron will do one channel and it proves out OK. Ignis aurum probat, measurementeria fortes circuites.😀
Να μην είναι πολύ βιαστική, είτε με επαίνους ή φταίει? Μιλούν πάντα σαν να έδιναν αποδείξεις πριν από την απόφαση-έδρα των Θεών
Ok then😉
Be not too hasty either with praise or blame; speak always as though you were giving evidence before the judgement-seat of the Gods.
/Lucius Annaeus Salaceus
Tried some parts to see how the board solders. Looks like this 2mm board is very good quality for that. I used 0.5mm eutectic solder wire. No bad residue or fumes, no blob like joints. Flows and sticks to this one great. Because to import a heavy reel of Kester isn't that economical, I got 50g of Mechanic HX-T100 leaded 63-37. Proved fine. Some Takman REY and a Z-Foil went in well. The big one has to stay board proud because it will dissipate some heat. Got to get 1,2,3,4 ON DIP because my 1,2, ON stash jump the pitch when touching together. Bummer.
He he found at a shop downtown. Blue like the PCB even. Nice thing, with just 4 different values from 120R to 1K and the 47K input load permanent I get many combinations by flicking the switches. From 62 Ohm up to 1K or 47K straight. Last one is for TAS readers.😀
Nice that they have those at Carrefour😀
Carrefour has left the debt ridden land. They moved out some time ago. An old one man show electronics shop in the city centre it was.
Its the label only now. They pulled out and sold their stake to their local partner Marinopoulos last summer. For Cyprus and Balkans also.
The thingy ticks afterall
It gave 63dB and 20.6VP-P before clip with 2x 369s of 11mA Idss at the input stage. Good for low MC this one config. I could not get the scope to lock on any 50Hz at all. Weird given the open air crude test. I have seen a few practical things I would want to revise. Minor PCB parts fitting stuff and a couple of designations I mean. Do you like the blue or in black it will be better?
- Analogue Source
- Simplistic NJFET RIAA
