1000W Simple PA Amplifier
This Amplifier is simple class AB design for PA
Reactions: paolocognigni
Hi Apexaudio
greetings 1000 watt simple PA amplifier can it be used in 2 ohms at 110 dc
supply rails what would the power be with MJL21195 MJL21196 with same supply just finished another similar PA amp with 110 volt dc supply rails
warm regards
andrew lebon
.......... but it will be a nightmare to dissipate all those watts wasted as heat...........
With 1r0 emitter resistors on the outputs, the output bias will be approximately 26mA for optimum ClassAB.
This gives an output stage dissipation of ~51W for all 18 devices. Add another 6W for the drivers. Quite manageable, especially for a "big" amplifier that will probably be fan cooled.
This amp will be cooled with two 0,14A/220V fans in parallel 120x120mm size.
