Can you disable DAC on O2 ODAC?
By "O2 ODAC" do you mean something like this, an amplifier and a DAC in the same chassis, or are you asking if the ODAC can be used as an amplifier?
In the first case yes, just bypass the DAC by using the analog input, in the second case it is a clear no. The DAC cannot drive headphones directly.
Yes it is O2 Dac and AMP in same case.
So then I just connect 3.5mm cable + powersupply and the amp should work?
