DCX2496 EQ Tips... Does anyone had success with Equalization of bass is Small Rooms?
these links are easier to open:
Waterfall showing my ringing room...
http://postimg.org/image/fqdggwjut/
sub 1 Dayton near the listening position
View image: Captura de Tela 2013 04 17 às 22 09 52
sub 2 SVS in the back wall corner
View image: Captura de Tela 2013 04 17 às 22 10 10
sub 3 Dyton in the backwall, not corner
View image: Captura de Tela 2013 04 17 às 22 10 18
sub1, 2 and 3 without the mains.
View image: Captura de Tela 2013 04 17 às 22 09 43
mains + sub1 ,sub2 and sub3
View image: Captura de Tela 2013 04 17 às 22 09 33
sub 1 with 90 phase invert, sub 2 with 180 phase invert and sub 3 normal phase
View image: Captura de Tela 2013 04 17 às 22 10 27
all measurements
View image: Captura de Tela 2013 04 17 às 22 09 14
Thanks.
Could you put one sub directly behind the listening chair. It should be at shoulder height as close as possible to your ears. Disconnect all other subs. Then measure the response at the listening position where your head would be.
this are my new measurements.
As oriented by Dr. Geddes, I repositioned my 3rd sub, the one that it's near me, so I placed in the left side wall, at 1/3 the corner.
The measurements are done with HOLM and REW, also I measured with an Ipad software that has a FFT from studio six digital.😀
There is no EQ or delay adjust at the DCX.
Something that I'm little confused is with the output loudness,😕 how I calculate the best volume to measure? I'm using the volume I used to listen, but I'm not certain hat this is the correct approach.
Now lets listen to the Audio GURUs...:soapbox:
the 3 subs without the mains, phases zero.
the 3 subs without the mains, phases inverted 180.
Simulation of your room
I tried to simulate your room with an online version of a room simulator located at Lautsprecher Rechner - AUDIO . I "moved" 3 subs until I got the smoothest response fo your listening position.
I ended up with one sub in the front right corner, on sub in the left back corner and one sub on right wall 2 meters away from the front right corner.
