A-class Preamp PSU
A-class PSU,used in Clepsidra preamplifier:
Csom the 22r or 10r have only 650mV across them.
Pd ~ 0.65^2 / 10r = 42mW, 22r is Pd=19mW
That's ~ 7% of the rating of a standard 600mW resistor.
You could 400mW or 500mW here.
If you have ¼W as your standard stock, then use them.
Thank you sir for your kind reply. I will follow your words.
Pardon my ignorance but could you kindly tell me what are the advantages of this circuit over that using 7815 and 7915 in a preamp section made with opamp like TLO72 or TLO74?
Would you be better to learn the tiny bit of arithmetic so that you too can select without the need to follow my words?
Awwww Sire,
You are really ruthless!
Why torture a half-educated man leading him to the uncharted territory of mathamagic where the wizards reside?
And it's safer to "follow" the path of respected audio gurus like you and Mr. Mile and others.
hehe. :D
And my second question is still unanswered. :)
PCB Ready!
Okay! PCB made, drilled.
I also applied a coating of resin dissolved in thinner to protect it from weather corrosion.
I bought TIP41C and TIP42c today.
But BF245A and BC560C are not available in my locality. Neither 2SK246. :(
I ordered a local shop keeper to bring me the required parts. Today he reported that BF245A and BC560C are NOT available, neither 2SK246.
Could you kindly recommend any other alternatives?
Thank you.
