Type of outputtransistors in a Classé Audio DR-3
Does anybody what type of TO3 outputtranssistors are used in a Class´s Audio DR-3 or maybe DR-2/DR-3B/DR-3 VHC.
Bias and DC offset are drifting in one channel so I can´t operate the unit properly.
Do have the service manual and I know bias must be 0.8 Volts measured over a one of the big 10 Watt resistors between input PCB and big blue PSU lytics and DC ±4mv max.
Suggestion handwritten on the servicemanual is to substitute both the inputtransistors MPSA53 TO92´s located at Q3 and Q4 to stabilize the fluctuating DC by MSP8599´s.
Any suggestions?
Did listen to this amp with reduced bias (130 Watts intake fom AC instead of the 500 Watts specified and it sounded so wonderful that I would love to keep it!
Thans in advance,
Robert
Addendum
I just switched all the outputtransistors from one channel to the other but the problem remains in the same channel.
Whenever I connect a dummyload to the problem channel the bias immediately doubles and the DC Offset goes from ±15 mV to -50mV or even higher.
The other channel remains stable.
I can see that in the problem channel all outputtransistors haven been replaced by new pairs of 11015/16 highcurrent Darlingtons and the original 5 MPS8599 by MPSA53´s. So it seems they already tried to solve this problem and did not succeed or the problem was only temporarly solved.
Any help would be great?
do you have a scope, that sounds like the amp is oscillating when a load is attached. A scope would help to check.
Check the zorbel cap and resistor, C9 ,C5-7 and D3/4.
check the rail resistorsR33/34.
If it is oscillating a Miller? cap (100pf) across BC of Q10 may help
Thanks!
I´m not a technician and do not have a scope but all the caps you mentioned are those red and green WIMA´s.
The Zobel cap is C14 and the resistor is R31 inside the 2.5mH inductor probably?
The only way to check that resistor is to desolder the inductor I think.
With D3/4 you mean the Diodes CR-3 and CR-4.
On the attached image you can see that these have been replaced also in the problem channel.
Miller Cap and Scope
I'm bidding on a Tektronix 2225 right now.
Miller cap like this:
It´s getting weirder!
As soon as I operate the leftchannel alone (rightchannel AC fuse disconnected) everything seems fine. I can stabilize the DC Offset at ± 1mV and the bias remains stable at 400mV also.
As soon as I reconnect the rightchannel the bias in the leftchannel more the doubles in a split second and the DC offset in the leftchannel goes to -150 mV immediately and settles after a few seconds at 40 mV.
I have no glue to be honest what is the case of this strange behaviour.
Simple solution:
I desoldered the only connection between the left- and rightchannel (the small orange wire at the back) soldering points denoted as ´E2´ and ´bridge´ and voilà both channels happy and stable...
Can´t bridge now off course but hey one stereo will be able to drive my speakers easily.
It´s a bit dissatisfying of course and I have to find the offender in the small bridging part of the rightchannel frontend someday...🙄
