Hi there any one can help me design pre-amp tube
What the Pre-amp tube are 400V AC(100mA) and one two 12.6V AC(1A)
The transformer can supply 320V(100mA) and 0-18V(1A)
Tks
Tks
I assume you mean 400V DC at 100mA? That seems a lot for a preamp, and too much for your transformer. A 320V 100mA AC secondary will provide perhaps 40mA DC from a capacitor input PSU.
I designed a disco valve mixer and used 110VDC. 110VDC is safer to work with for a newbie but will still bite a bit.
Do you want valve rectification or solid state ?
@DF96 : Yes, the pre-amp input V are in DC
@nigelwright7557, I am guessing better with Valve rectification? What do you think?
To be honest I am just looking design that cheapest and very good PS (lol...)
Help me please.... I am learning a lot from this site
How do you know your preamp needs 400V DC and needs 100mA current?What the Pre-amp tube are 400V AC(100mA)
"one two?" 😕and one two 12.6V AC(1A)
How many and which tubes does your preamp use?
Hint: a schematic would be useful.
This is what i got from the user manual
"one two?" 😕
Meaning there is also one output (from PS PCB) and going to TWO (in for Pre-amp PCB)
How many and which tubes does your preamp use? (6 Pcs. this is clone of JP200)
http://www.diyaudio.com/forums/power-supplies/230726-there-any-thing-wrong-design.html
Sorry but which user manual?How do you know your preamp needs 400V DC and needs 100mA current?
On your OP you refer toHow can you have a user manual for something that's not yet designed?😕help me design pre-amp tube
"6 pcs" ..... of *what*?How many and which tubes does your preamp use? (6 Pcs. this is clone of JP200)
Don't know what a JP200 is, that's why I asked a schematic of what you are building.
Sorry, no Preamp schematic to be found there.Hint: a schematic would be useful.
I have this pre-amp as DIY kid from analog metric
My first experience building the kit
it was horrible the original kit that they have (a lot of hum)
so I decided to follow this guy Norbert R
Tube DIY Asylum
I change all the resistor, capacitor and sound become so amazing .... way better than original one
but I still have the problem with the Power supply. In Norbert R, he has PS200 ( http://analogmetric.com/download/Variable Tube Voltage Regulator PS200 User Manual.pdf ) and I have regular one ( HV400 Variable High Voltage Regulator Kit (100-300V 0.1A & 0-30V 5A)_Power Supply Kit_Analog Metric - DIY Audio Kit )
Well at that time I did not know much about which PS I should use and they send me the kit
here is the link for user manual
Pre-amp
Tube DIY Asylum
I hope this will clear up
Tube DIY Asylum
Pre-amp
Tube DIY Asylum
- Power Supplies
- PS design for tube pre-amp
