500W PA amplifier with Limiter
and this is from apex audio
How many watt you get using this method "TEF" ?
Salam kenal
55-0-55 A.C. that is around 77-0-77 Volt D.C. if I am correct not 90-0-90 as in layout, Did you have to put a delay start in it, how was the heat of outputs on load,Is there any more changes in component value in your layout.thanks in advance for getting the reply.
77-0-77 VDC absolutely right. scheme while no corresponding change in the scheme Mr. Mile, the final transistor is not too hot, just hot on the driver, but after being given the fan its ok. I wear a speaker protector existing B500 standard fan speed control,
regards
For checking
Layout H 900 TEF and B 500 TEF
Hello Everyone... Hope it's ok to post it here since this is just a reply to the post above. I manage to merge the parts & PCB layout hoping anyone can checked if its correct. There are some parts which values are not available... hoping also anyone can give suggestion. Anyone else have tried this layout aside from Mr. Liem Poo?
many thanks in advance
additional pics. my board is a mirror image, so i have to solder the all trans and ic to the copperside. 😛
got few questions. 470pF number code is 471, but electronic sales staff gave me 470. for 33pF number code is 330, but staff gave me 331. i'm doubtful if it is correct. is this correct?
