@npetralias:
What are your suggestions regarding the optimal configuration for your player in a win 7-64 machine? What makes the purest sound, for example: asio or direct sound or wasapi? Soundcard or no soundcard at all? What are your experiences?
Luki
Luki
@npetralias:
Luki
Hello,
The best you can do is to use SSD hard disks for both OS and music, disable Virtual Memory, disable your Soundcard (if using a DAC), set Wasapi to "ON" (i know...sorry...), minimize the running processes-services and make a linear regulated Power Supply for you PC. This last thing may be a bit difficult for a Desktop PC but it is very easy for a netbook (an LM338K is usually enough).
You may also check again Wasapi after changing the sampling rate in Control Panel\Hardware and Sound\Sound\Playback device\Properties\Advanced.
No success. Whatever sample rate I choose, no sound. This is kind of frustrating, but on the other hand, the sound without Wasapi is so great, I´m wondering, what unknown bliss is coming if....
Luki
Luki
Luki
I have ordered a DAC with the same chipset (Tenor 7022) in order to be able to debug... it's up to china mail now 🙂
Yes 🙂
Luki
Yor DAC arrived and the problem you mention occured.
After installing Teralink drivers everything are just fine.
Teralink 64bit driver, http://hifimediy.com/wp-content/uploads/TeralinkX2Win764Bitdrive.rar
Teralink 32bit driver, http://hifimediy.com/wp-content/uploads/usb3pkg_v0p7p3p2a_20100401.zip
Great DAC, by the way (after a 50 hrs burn in)...actually even better after installing some caps and a linear regulated 5V psu.
ps. A new version is available with minor changes (track name display etc)
http://www.purediy.gr/downloads/pp.html
I use a number of DAC, the Chinese Matrix Cube based on Wolfson chipset, and also lately this cheap DAC based on ES9023 chipset, from HIFImeDIY.com costs me $59(model:UAE+), you should try this DAC it is excellent value for money, sounds very good.
Both these DACs I experienced the same problem. They don't use drivers that comes with the DAC but rather drivers inherent/embedded in Windows 7.
Please try the above drivers for TE7022 chipset (your interface)
thanks I will.
First of all: Thank you very much for your work! Everytime I hear my music, I enjoy your fabalous player - unfortunately still without wasapi. I deinstalled both the windows and the HA2 drivers, that came with the device, deleted the folder with the "old" pureplayer, pasted the "new" pureplayer and installed the teralink drivers. I tried probably every possible combin ation of samplerates and so on, but I still can get no sound through pureplayer in wasapi-mode and my usb/spdif device. If I use soundcard as standard-device or foobar as a player, no problem.
Luki from Bochum
Success, but -
For several reasons I considered to install win 8pro (64bit). OK, last weekend I did it. For the first time I was able to transport the soundfiles via pureplayer and the HA2-USB/SPDIF converter (with the teralink drivers) in wasapi-mode to my DAC and amplifier. Wow! But - now there is a crackle to hear, some kind of distortion or overmodulation. What the hell can this be?
Sincerely i have no idea, never tried Widows 8. Up to now Microsoft makes a good OS release followed by a horrible followed by a better and so on, so i was waiting for the next one 😀
I will try it ASAP but in the meantime maybe someone else using Windows 8 can help.
Hi
i tried the player with window8 and works with 16/44.1 files . I have not evaluate it properly as it was late in the evening.
Unable to play 24/ 192 files though.
thanks for the player.
kp93300
kp93300
How are you? My friend of mine who happens to be an audiophile himself and a DIY member had introduced me to ur pureplayer software and I would say it is very good that until now I am still using it for my serious listening pleasure....Thank u so much for this.....
Keep up ur good work and contribution in this field.... more power to u and wishing U all the best!!
- PC Based
- Pure Player
