SOLD OUT--- 12,000Uf 80 Volt cap
Joined 2002
I just got in some Cornell Dubilier 12,000Uf 80V Caps
P/N 4CMX123UO80AC8
They measure 1 1/4" Dia and 4 1/8" Tall
Steve
Nice part. It appears to have been "customized" for Hewlett-Packard. There's a special 4X4 part number "0180-4570". Good price too.
Here's some info from the parts database:
FUNCTIONAL/PHYSICAL INFORMATION:
Type : N/A
Fxd or Var : FIXED
Std Cat Item : NO
Diel Matl : ALUMINUM ELECT
No of Sect : 1
Cap Nom : 0.012 F
C Var Min : N/A F
C Var Max : N/A F
C Tol + : -10 %
C Tol - : 75 %
Oprg Temp Min : -40 deg C
Oprg Temp Max : 85 deg C
Test Frequency Nom : 1000 Hz
WV-max : 80 V
Lkg Cur Max : 4.8 mA
EIA code : NON HP STANDARD
Pkg Tp : STANDOFF
Pkg Matl : NOT SPECIFIED
Pkg Shp : CYLINDRICAL
Termn Tp : WIRE LEADS
Termn Base Matl : NOT SPECIFIED
Termn Barr Matl : NOT SPECIFIED
Termn Outer Pltg Matl : NOT SPECIFIED
No Of Pkg Pins : 2
Termn Spcl Fmg : NO
Mtg Tp : SOLDER
Pkg Lg English : 1.406 in
Pkg Wd English : 1.406 in
Pkg Ht English : 4.375 in
Cmpnt Ht English : 4.375 in
Termn Row Sp English : N/A in
Termn Pitch Sp English : N/S in
Termn Dia Min English : N/S in
Termn Dia Max English : N/S in
Termn Lg Min English : 0.235 in
Pkg Lg Metric : N/S m
Pkg Wd Metric : N/S m
Pkg Ht Metric : N/S m
Cmpnt Ht Metric : N/S m
Termn Row Spcg Metric : N/A m
Termn Pitch Sp Metric : N/S m
Termn Dia Min Metric : N/S m
Termn Dia Max Metric : N/S m
Termn Lg Min Metric : N/S m
Pkg Des : NOT ASSIGNED
Mtg Tech : THROUGH HOLE
Pkg Orient : YES
Source Control : STRICT SOURCE
A) Name : CORNELL-DUBILIER ELECTRONICS INC
Name Abbreviation : CDEI
City : WAYNE
Geographic Area Name : NJ
Country Code : US
Supplier Status : ACTIVE
Manufacturer Part Number : 4CMX123U080AC8
Manufacturer Part Number Status : ACTIVE
Manufacturer Part Number Approval : A
Discontinuance Date :
Joined 2002
Charlie....
There are the 2 leads with the metal rings around them which are the
positive and negative while the one on top is a dummy
a positioning pin and the 3 protrusions are for holding the cap on there
PC board.
These are leads and not ilet or screw down caps, I do not see any problems
with soldering to them. You can always cover your work with shrink tubing
or Teflon tubing..
Steve
Joined 2002
I just need to know how can I get to purchase 6 of these items
I still have some in stock...
I'll need to know where you are to quote a shipping cost. It should be
in the USA I can fit 6 in a USPS Flat Rate Video box for $7.50 overseas
for $27.00.
In the USA and Canada you can call me TOLL FREE at
1 866 4- APEX JR ---- 1 866 427-3957
or PM me
