irs3000d
pls someone tell me this layout is correct or not?
pls comment for this amp.
hi nazir
i have made the ir900 and the ir4k5 both work but you have to be extra careful when soldering ,because the tracks are small.
i haven't tried the ir3000 but there are a lot of complains from diyers.
i would recommend you go with manoj,s aud600 it is powerfull and many diyers have build it including me
hi
i have made IRS300 and it work nicely
i use 6k8 as Rss and test it with duble 60 & 75.
is 6k8 right resistance for this voltage ?
how can I know how much must use per diferent voltage ?
i can't find orginal mosfets then i use IRFP250
hef4049 Instead cd4049
