What's the output voltage of your Audioquest Onyx LOMC? I suspect can be enough with your 1:10 SUT & Itch.
I'm using an Audioquest Onyx LOMC, and currently running it through a set of vintage Shure SUT 1:10 (which I like a lot). Arm is a Sumiko Premier MMT on a modified VPI HW 19 MKIII w/outboard motor. So far I have been happy with a Siren Song, SB cascode 12AY7, and a Salas NJFet RIAA w/SSHV reg (thanks Salas for the great designs). Both the Siren Song and NJFet are really quiet.
The Itch along the 1:10 SUT should suffice for gain even if your cart is 0.2mV to 0.3mV. Already having a line preamp with some gain presumed.
I had a hard time finding any info on it. All I know it is close to a Audioquest AQB100MH, which is listed as 1.6mv (was built by Scantech and rebranded and labeled for the US). I do think that the rated output is correct for the Onyx. It's no more that 2mv. Yes I do have a line stage, a 26 5:1 xfmr coupled.
I didn't find any info of your cart, AQB100MH have load impedance 47K is the same like your Onix?
Hi Salas
I am now studying the Itch and allready have some basic questions:
In the first stage you use a rather highish plate resistor for the lower triode (R2 = 82k) and I believe you do so because you do not need a large voltage swing on the output of that mu stage.
Anyway, the dynamic impedance of that resistor should be around R2 / (1 - Avcf)
What value should I consider for Avcf (Voltage gain of the CF on top?)
Around 0.9 ?
Around 0.9 ?
Second question:
I see you ground V1 V2 filament heater supply but you bias V3 V4 filament supply at half B+... why ?
I think so, that's the way I have it loaded through my SUT.
BTW, I did a search through all my schematics I've archived over the years, and found a very similar circuit to the itch. I was by the late great N. Shishido, published in MJ mag in the 80's and later republished in Sound Practices. Dual 6DJ8 with a passive Tango LCR riaa between stages and 1:10/20/40 Tango SUT input. The 6N1p input and the SSHV should really make this itch circuit sing (very clever Salas).
What you may learn...Shishido had done alike is pretty nice. I would never use same amount gain stages, the BGs, the high bias commanded for driving the LCR, and the stoppers though. I am confident the Itch is 10dB better for noise by implementing the head amp concept and possibly has more accurate EQ.
Hi Salas
Around 0.9 ?
Acts as a current source the top part. Increases gain and PSRR. The first stage has high mu and high rp so it gets a highish plate load for linearity in low swing even, because it lacks cathode degeneration for absolute minimum en (input noise equivalent) reasons avoiding electrolytic decoupling also.
Second question:
The upper half would violate its cathode to heater max spec if done otherwise.
I understand the top tube acts like a ccs so the lower tube sees a much larger dynamic plate resistance and that makes it more linear ok
Thank you for the filament explaining... I was not aware of the cathode to heater max spec.
Now, please indulge my lack of knowledge.... I am starting to understand tubes now but still do not know how to bias a triode... I did not know oine could make Vgrid = Vcathode =0 and make it work like a fet at Idss ....
Would you please enlighten me ?
Its not like that. The current forced through as fixed in the upper part makes it bias. The valve type should be carefully selected here to be linear enough at low current and having minimal grid leakage. Batch quality can be easier to detect in such "naked" bias arrangement in high gain input position. Maybe Fellipe had felt that subjectively when choosing input valves.
Yes Salas big improvement using very good input valves.🙂
N.B. Have you in mind to desgin a tube headphone amp for high Z headphones?
Erno Borbely likes the Grados😉 and I love my Sennhs HD600🙂
If I owned Grados didn't look for headphones amps: I have Erno Borbely balanced lineamp....
Maybe if I get other than Grado that I have.
You are welcome to Sennhs HD600🙂
Thank you again... I was not understanding how a triode without negative grid bias could cope with positive signal overdrive correctly.
Now another question.... It seems penthodes make much better CCS than triodes.... why did you choose a triode for the upper CF ?
- Analogue Source
- Valve Itch phono
