Please Help: 6CJ3 Damper Diode Tube as Rectifier Question
Cap input
Just wondering if I can drop in to this thread and ask : ( Thomas ? )
I'm wondering about cap-input issues when using dampers like 6CJ3 .
Designing a power supply that will deliver about 300mA at 460V .
Hybrid bridge using diodes and 2-off 6CJ3 from a non-c.t. winding .
I'm getting close to the limit of the 6CJ3's as PSUD suggests they will be running about 335mA rms . May have to go to 4 smaller diodes or perhaps 2-off EY500A .
Question is - how will they cope with cap-input, as this circuit requires ( for reasons too long to explain ) about 20uF input cap ?
For what it is worth, I have a pair of 2a3 amity amps that use a pair of 6cj3 dampers in a hybrid bridge that I have used for several years with a 75uf input cap. They are being fed by a lundahl mains transformer that has two 250 volt windings in parallel, which results in a low dcr source. I have had no problems whatsoever with them facing a relatively large turn on surge.
Thanks Jim - very relevant info .
Interestingly I used pairs of 6CJ3's on a c.t full-wave supply to power 'Aurora' monoblocks a few years ago. Those were running VV32's , so the demand was high-ish , but only 1uF input cap .
Anyway, I guess it's the peak current that is affected by the cap input size ? - and they can run 2A approx .
Actually 6CM3 is better for rms current , just been checking .
Yeah, I remember reading about your build back when I was building mine. These originally began life as 300Bs, but I could never get them quiet enough, and I thought the difficulty in driving them always resulted in what I would term an "icy" sound, which I attributed to section mismatch in ecc99s I was using as drivers. 2a3s amps are silent, and I use a 5695 as a driver, which have really good section balance. I use a separate rectifier for the driver, a 5ar4 into a choke input with a gas regulator tube. Sounds really good, but I rarely use it, as I have become more of a SE listener.
6DW4 alternative
Glad have found this thread. I was looking for "something less punchy" than silicone rectifiers for my 211 amp. The 6DW4 looks like a ligh version of 6CJ3 with only 350 mA current drive but 1.2A for heater (PIV 4,5 kV). With a CT transformer, two tubes don't draw too much.
Hi!
The PIV rating is given for TV Damper service. It needs to be considerably derated for rectifier service. I would derate at least by 50%.
In your case you will have PIV of over 2500V, depending on the filter after the rectifier. Which means you are close to the limits.
I wouldn't recommend it. For such voltages I prefer full wave bridge rectification with 4 diodes and a single 1000V secondary. PIV is half in the bridge arrangement. But it would require 3 separate heater windings.
Best regards
Thomas
Thomas,
The "OP" stated that the power trafo is 1000-0-1000. So, a 4 diode bridge is out. Regarding your PIV concerns, headroom can be gained by installing a 2 part stack of UF5408 SS diodes in series with the plate of each 6CJ3.
FWIW, I'm with you in preferring bridge rectification at these dangerous voltage levels.
Hi Eli,
Yes you are right, but maybe he does not have the transformer yet.
Also your suggestion of enhancing PIV is valid of course.
The 6BY5 is the only TV damper tube which also has specs for rectifier service. Rectifier PIV is derated about half. Hence my suggestion to derate at least 50% in this case too.
And from experience I know that the rectifier PIV rating of the 6BY5 is not conservative. It will break down if operated beyond that.
Best regards
Thomas
At home I have three huge transformers available (military) FREED 1000-0-1000V (500mA) with a 115V primary. On the transformers is also spelled "INTERMITTENT DUTY" (?) Do not know what it means, electronically speaking.
I also have available a transformer with 0-600-700-800-900-1000V (1A).
My idea is to build a SEP that GM70 with work possibly under 1000V.
Perhaps the second transformer would give me less trouble taking advantage of the 600 or 700V outlet.
I would understand (Thomas I can answer this question) what is the limit of safety work in a power supply with a pair of 6CJ3?
