F5 with 2SK2013/2SJ313
what is different from the Pass BA-3 frontend ?
looking at schematics I see only minor difernces
I really can't figure out why this is a poweramp, and the BA-3 only a gain/driver stage :scratch:
btw, some time ago I worked hard to find good TO-220 devices for the F5
maybe some of them could be good ?
or is it all down to these special Toshiba devices ?
And where do you discover the similarity? Same transistor types?
Just for fun, here is a little pcb for your amp. Each five MOSFETs allow either lower bias and higher supply voltage rails for more power@8Ohms or more power@4Ohms with 400mA bias (total 2A per rail) and +-20V supplies.
I would like a pair of boards also, Per - can easily trim them down to 3 o/p Fets if required -
Could you add 2 small electro/solid poly caps across the rails to a separate 0Volt point near the jfet input, maybe 47uF+ ...
What about those: Panasonic FP V low ESR SMD electrolytics EEEFP1V470AP (~ EUR .30 each here in Germany)? Send PM with your email address and I'll mail the datasheet.
