I'm on the list for 2 more. I have only built the first pair and this will make 4 more to go, but it is a great sounding amp and I have to plan for future projects.
Dario,
It is only one man's opinion, and I wouldn't want to delay others who are anxious to get their first FE, but that is a nice price break at 50 boards, so I wouldn't mind delaying until we got there.
Dario,
You're right there's a nice price break from 50 kits (not boards, each kit = 2 boards).
25 kits is the minimum quantity necessary to order boards but it would be nice to reach 50 kits/pairs (100 boards) so to have the lower price.
It's also for this reason that the GB will remain open until the end of February... 😉
Welcome Shoom,
with you we reached the minimum quantity of 25 kits, now the goal is to reach 50 kits for the price break 🙂
Welcome Shoom,
Thanks Dario
nice to push things along a little.
looks like an interesting build.😎
TBH I was dreaming about cyrus mono x 300 mono blocks, but because of the price It was all too impossible.
Would love to know how FE would stand against my reference "shoeboxes" 😀
Hi Dario,
There is a toroid group buy going on and I was thinking on gaffing a couple. Does your design have the same power requirements as a normal lm3886 type amp, 18-22v for 4ohm speakers and 23-36v for 8ohm speakers? These toroids are 400-800va ..is this ok?
kind regards,
Ron
kind regards,
Ron
I also signed in the hope to soon feel the sound of this intriguing amplifier.
Welcome🙂
Transformer requirements are:
160VA min, dual secondaries 24-25V (8 Ohm) or 21-22V (4 Ohm)
Higher VA ratings give a fuller sound,
R-Cores requirements are lower my 120VA one sound louder than a 225VA toroid.
For each kit (2 channel) two tranformers are required.
I would suggest partecipants to read at least the RC build thread, a lot of questions are already answered on it.
Render of PCBs
I've just figured out that I didn't posted any image of the final boards...
You'll find attached a render of the PCBs.
The main difference from Release Candidate boards is the fixed cofiguration for C9/R10 (different from My_Ref original one, as suggested by KSTR and tested during RC phase).
Other minor differences are some holes diameter and a more refined trace toward R3.
One final note about price... we've reached 35 kits/70 PCBs, price so far dropped to 32€/kit
what are the board dimensions with premium bom (caps)? do you think a stereo set + toroid can fit on the galaxy hifi2000 enclosures? (the 23x28x8)
Like this one?
But you will probably have to use R-Cores like I did, toroids are larger...
Hello Dario,
I read in the past great reviews of My_Ref amplifiers and I'm considering to build one for myself, then I'm happy that you are kindly starting a GB of an improved implementation.
I have some questions about your implementation (maybe some of them are covered elsewhere, this is just to collect info here):
1) about the transformer/s: do you think that 22Vac secondaries are ok?
2) is it known the behavior of my_ref amplifiers with low impedance speakers? (I have 4Ohm speakers, even with lower impedance minimum...)
3) about your kit, is the BOM available? (I read that you made a cost estimation already). If not, will you make one available here?
Thank you,
Daniele
Thank you,
Daniele
Ciao Daniele,
For 4 Ohm speakers, yes
It really depends on the speakers...
The My_Ref (and the FE has same advantages/limitations in this regard) has great driving abilities on 8 Ohm speakers and on most 4 Ohm (21-22V secories required) ones but it's still a 40W amp and very demanding speakers can cause troubles.
But I've no way to tell it in advance...
Both BOMs can be found on the first post of Release Candidate thread.
The countries race
So far:
IT 6 US 4 CA 4 UK 3 CH 2 SI 1 RU 1 RO 1 ES 1 DK 1 DE 1 AU 1
Various new countries (Vs RC), a lot of partecipants from Canada 🙂
So far:
- Group Buys
- My_Ref Fremen Edition Interest/Group Buy
