Ever think of building a Cornu Spiral horn? Now you can!
Am I seeing that correctly, that the driver is mounted off center so there will be 6 different length horns? If so you certainly have all the bases covered with tuning frequency. 😉
The foam joint tape - is that your spiral template? hehe, what, are you only building two of these?
As far as the glue drying, I would first install a 3/8" wide strip of paper to the cardboard edge with PVA glue, let it dry and then you will have a wider surface to put your glue on for the baffle piece.
I don't seem to have any 20" square pieces here so I am thinking about a Suprabaffle instead. Here is the shape I am thinking. It will be made of wood and glued to the foam. Any thoughts?
Hi there, gentelemen. I've been following this thread very closely. AKA lurking for some time.
I have all the material to build a pair of 24" cornu's. I saw xrk971 mention using the TangBand W4-1320SIF and was wondering if it would be a good candidate. If so, what would the height of the spirals? 4.5"? This is my first go and hot glue box building but am excited to try it out. Thanks for all your help and insight. Very impressed with all the knowledge on this forum
Thanks a million xrk971! I appreciate it. I' m going to get all the internals cut tomorrow night and employ the better half's hands this weekend to get them glued up. Weather is supposed to be crappy so it will be a great inside job.
I will get some pictures up when I get them stuck together.
Thanks again
Thanks a million xrk971! I appreciate the information. I'm going to get the 4.5 inch strips cut tomorrow night. I have employed the better half's hands to help this weekend. The weather is going to be cold and snowy so I'm really liking the fact I don't have to go out to the garage for this project.
I'll get some pictures up of the finished product.
Thanks again for all your help
The saga continues...
So good to see the new persons on board. Here's what happened between work and when we have to go out (15 minutes from now)
JVC drivers on the Suprabaffles. Might want to remove a little insulation as the bass is a little light. [no **** Cal, they're 3" drivers]. Will have more time later but this is a busy week so I will experiment when I can.
Pics are no flash then flash.
I wanted to add that, ideally, you should make a 27.5 in Cornu for the W4-1320SIF as it has a nice Fs of around 70 Hz, which is more suited for the longer channels afforded by the full-size design. If you do not need the deeper bass extension, the 24 in still works. The 4.5 in channel depth is good still.
Cutting the Strips
Just bought a box of blades for my sheetrock knife. Going to cut the strips tonight after work!
http://www.diyaudio.com/forums/members/xrk971.html
Ryani - You might also want to pick up a special kind of knife that is set up to make just a shallow cut in the surface. I have a Scotch-brand (about $5). When you slit crosswise at narrow intervals you can break the foam coreboard over the ruler of a t-square easily. This will allow you to do the bending so you get an accurate curve.
Thanks for the heads up. I was wondering if bigger would be better but when I went to Menards they had 24"x24"x1/4" boards on sale for 3.99 a piece so that swayed my decision. Plus being my first foray into this style of speaker box I wanted to keep it simple as possible.
That's a great deal on quarter inch ply and probably would sway me too. The problem with the 27.6 in size is that there is a lot of waste as you can only make 3 sheets with a 4x8 foot panel. It requires you to buy two sheets. On the other hand, if I were to pursue a realistic copy of the commercial Cornu with two layers it works out to two sheets of 4x8 ft ply for two speaker as there are 3 layers ea.
