Today I picked up some rare Paisley AE300 Speakers from original owner.
They are all original in near mint condition, 1 small scratch on 1 side.
Only issue is 1 back speaker terminal came loose so it needs tightening.
They sound real nice and warm with good bass as well !
Not bad for a 6.5" speaker. I will also note that they are heavy suckers !
Anyone have experience with these ?
Some pics:
SPECS:
Enclosure type: Bass reflex
System resonance: 42 HZ
Woofer Diameter: 6.5"
Tweeter Diameter: 1.0"
Crossover Frequencies: 2.5 khz
Tweeter type: Dome
Frequency Response: 38 Hz-20 khz +/- 2db
Efficiency: 84 db
Power Handling: 60 watts
Nominal Impedance: 4 ohms
Enclosure Demensions: 24x26x40 cm's / 9.4" x 10.2" x 15.7"
System Weight: 12.75 kg
Price: $549.00 a pair. ($1500+ in 2013 money)
Audio Canada Magazine, August/September 1981
Made in Canada
Some pics:
SPECS:
Tweeter type: Dome
Efficiency: 84 db
Made in Canada
Nice find!!
Seems very well made as well.....I can picture those set on stands......you trying to find a sweet spot in the room to place em'.....
All you need now is a matching subwoofer.
Hours & hours listening to music.......moving the pair all over the room, trying to get the imaging & response down right.....I can see it all, clear as day.
I would take advantage to the max, that beautiful radius on the cabs....I'd leave the grills off....apply some absorbent felt on the face...
Again...NICE find!
________________________________________________________Rick......
Again...NICE find!
Looks like SEAS to me
Correct.
The Paisley AE series was Paisley's early model and used high quality off the shelf drivers like the Seas tweeter and with bextrene Audax woofer.
This same tweeter was used by Mission in the classic 770 and in many other higher end brands .
looking at the specifications I think they will only sound nice with ss amps and with a huge amount of power, at least 200w per channel, as the ls3/5a, power amp eaters. (84dB).
Maybe but the speakers are rated for 100 watts max
The good thing is that they are 6 ohms.
ho Rbcrx, the rated wattage of the speaker do not specifies the power of the amp, the best practice is to adopt a 1,5 to 2 x of the power rating of the speaker to match the power. I had 15 Ohms LS3/5a speakers, and they are 84dB, usually, they only sounded well with my manley ichiban powers, that are 600W each!
cheers.
cheers.
More likely to ruin speakers with not enough power than too much... I run a pair of 8" full ranges on 375 watts per channel.
Just had Jim at Fabaudio tighten the rear terminals so it will never come loose again ! Im going to use banana plugs on them as well. He also re-glued the grill cloths as well, free of charge.
Also, the spec sheet must be wrong. He measured the speaker impedance and these are 4ohms. I guess they used 6 ohms on the spec sheet because 4 ohm impedance werent really the norm back them.
Vintage amplifier watts or Modern amplifier watts ? Theres a difference.
Walnut .. for sure.looks like mahogany veneer chip, so heavy for sure. At least the quarter round gives a radius. 70s? Clueless about brand or drivers. TINY port though.
Walnut .. for sure.
Yep. American Walnut Veneer.
There's so little info on these speakers on the internet, or any paisley for that matter.
How so?
How so?
When comparing a vintage amp to a newer amp, with the same wattage figures,
the older amps seem to sound much louder, cleaner, crisper, than newer amps.
Also, alot of newer car audio amps state 1000w but only push out 200 watts max...
false advertising ?
false advertising ?
Got ya.
What the heck does that mean?
No Idea, just felt like posting it.. hhaha
Ian Paisley is a legend.
Just google: Ian Paisley, Mirage.
https://www.google.ca/search?q=ian+...&sugexp=chrome,mod=6&sourceid=chrome&ie=UTF-8
Yep, I know the history of Paisley Research.
The factory where these were made is just 20 minute drive from my house.
- Bought vintage Paisley AE300 speakers
